  3. Failed Write Clock Object Using Ansi C
Failed write clock object using ansi c
By Mohanraj , 1 May, 2020
we have downloaded the latest stack and compiled successfully.
connection is success in ciphered meter. but failed to write clock object. please find the trace below
RX: 7E A0 07 03 21 93 0F 01 7E 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 30 00 07 B2 6C 7E
TX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E
RX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 81 00 06 AC 14 88 6D 69 F6 7E
Invocation counter: -1407940498 (0xFFFFFFFFAC14886E)
RX: 7E A0 07 03 21 53 03 C7 7E 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
InitializeConnection
TX: 7E A0 07 03 61 93 69 47 7E
RX: 7E A0 07 03 61 93 69 47 7E 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 88 6E DB D9 86 21 4F 37 71 6B AF 49 C9 EC 97 C1 A0 F5 2F 5B EA E3 3E 80 91 98 65 24 F5 DF 7E
RX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 88 6E DB D9 86 21 4F 37 71 6B AF 49 C9 EC 97 C1 A0 F5 2F 5B EA E3 3E 80 91 98 65 24 F5 DF 7E 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 39 30 38 33 34 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 03 AA 92 16 5A 0E 2F 37 01 EE 65 48 CE EE C4 09 67 D8 B9 7F 2F 6C B8 FF 9D C3 D3 92 84 A8 7E
TX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 88 6F 2C 7C C7 BE 8A 80 0D 8D 8A 2D E3 54 5D 84 E6 4E 3B 0D 30 19 B3 A6 45 57 68 34 33 85 98 13 04 6E E6 75 3A 75 12 3F F7 DA D2 C4 28 B9 65 7E
RX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 88 6F 2C 7C C7 BE 8A 80 0D 8D 8A 2D E3 54 5D 84 E6 4E 3B 0D 30 19 B3 A6 45 57 68 34 33 85 98 13 04 6E E6 75 3A 75 12 3F F7 DA D2 C4 28 B9 65 7E 7E A0 37 61 03 52 0E 3A E6 E7 00 CF 29 30 00 00 03 AB 84 74 C9 0F CC 2B 50 63 DF CE 9D 23 DC D0 6A 10 83 77 CF BF 84 7F B2 54 EF AD FA 00 08 17 1F 58 21 9B CE FE 3B CB 7E
Writing the clock
TX: 7E A0 3A 03 61 54 A7 32 E6 E6 00 C9 2C 30 AC 14 88 71 B1 02 E9 CC F2 16 47 27 D6 95 43 8F 16 AC 37 13 C5 CD 79 30 94 63 30 8B C4 41 A4 01 8D 4B AE CF 3C 0B 21 60 BC 41 4E 5C 5A 7E
RX: 7E A0 3A 03 61 54 A7 32 E6 E6 00 C9 2C 30 AC 14 88 71 B1 02 E9 CC F2 16 47 27 D6 95 43 8F 16 AC 37 13 C5 CD 79 30 94 63 30 8B C4 41 A4 01 8D 4B AE CF 3C 0B 21 60 BC 41 4E 5C 5A 7E 7E A0 23 61 03 74 77 CF E6 E7 00 CD 15 30 00 00 03 AC 71 18 05 CB 6D 0F 5B 57 B7 67 4E FC D8 7F DF 1F 0B C0 7E
Write failed Clock 00.00.01.00.00.255:2 Access Error : Device reports a inconsistent Class or Object.
Please do help us to resolve this
Mohan Raj
6 years 2 months ago
Hi Mohan,
Hi Mohan,
Because your data is ciphered, I can't check the bytes. You are using Push-client address, not US.
Try to change that to the correct one.
Mohanraj
In reply to Hi Mohan, by Kurumi
Could you please tell how to correct that address. I have tried with 0x18 which is for high level password. But failed.
Mohan Raj.
Hi Mohan,
Hi Mohan,
If you are using Indian standard meters that use IS 15959-2, US address is 48 (0x30).
Mohanraj
This is what am passing as an argument and below is the trace. But still failed.
./bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -c 48 -s 1 -a High -P "0000000001035820" -C "AuthenticationEncryption" -g "0.0.0.1.0.255:2" -v "0.0.43.1.3.255" -t "Verbose" -I
updateInvocationCounter
RX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 81 00 06 AC 14 8B 02 F0 47 7E
Invocation counter: -1407939837 (0xFFFFFFFFAC148B03)
TX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 8B 03 86 E5 B9 B3 6D AE 28 7A 95 BD F5 EC E2 5C 8A 2D CB 6B E7 92 C9 81 FB F5 1E B9 4E 5D 7E
RX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 8B 03 86 E5 B9 B3 6D AE 28 7A 95 BD F5 EC E2 5C 8A 2D CB 6B E7 92 C9 81 FB F5 1E B9 4E 5D 7E 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 39 30 38 33 34 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 05 F0 10 1A E7 91 32 F9 C3 AD A2 01 BA 4C 45 98 AE 0A 54 C0 0D 40 5D B2 ED 5C 55 D5 DF A3 7E
TX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 8B 04 1E AB 2A 83 BC 5D 4B 6F 9C FF CA CD 81 52 A9 07 01 BC 24 CD 50 AB 5D 24 A1 26 C2 B1 7B 32 16 0B C4 B5 B6 44 45 CE 05 F4 F2 2E F8 09 3B 7E
RX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 8B 04 1E AB 2A 83 BC 5D 4B 6F 9C FF CA CD 81 52 A9 07 01 BC 24 CD 50 AB 5D 24 A1 26 C2 B1 7B 32 16 0B C4 B5 B6 44 45 CE 05 F4 F2 2E F8 09 3B 7E 7E A0 37 61 03 52 0E 3A E6 E7 00 CF 29 30 00 00 05 F1 31 F5 9D 57 1D 2E 88 ED 88 68 40 6D 76 41 AC 12 93 AB CE BE 47 43 C1 55 7F 76 C1 7C 4D E8 C1 9F AC A3 4C AE 82 83 7E
Writing the clock
TX: 7E A0 3A 03 61 54 A7 32 E6 E6 00 C9 2C 30 AC 14 8B 06 28 7E 9E DA 45 11 01 6E CE 9C 6A DD 33 6B CC 3C C2 E9 C6 36 B3 0F F3 AE 8C 8A 43 84 0F 2D C2 D8 0E 7D 3D 9D 8A EF 38 6E 76 7E
RX: 7E A0 3A 03 61 54 A7 32 E6 E6 00 C9 2C 30 AC 14 8B 06 28 7E 9E DA 45 11 01 6E CE 9C 6A DD 33 6B CC 3C C2 E9 C6 36 B3 0F F3 AE 8C 8A 43 84 0F 2D C2 D8 0E 7D 3D 9D 8A EF 38 6E 76 7E 7E A0 23 61 03 74 77 CF E6 E7 00 CD 15 30 00 00 05 F2 1D 17 CD 1C 7E AD 81 EB 37 43 20 9C 45 FE 78 1A 13 4B 7E
Mohan Raj
Hi Mohan ,
Hi Mohan ,
If you connect with GXDLMSDirector can you see the clock object? What is the access level? Can you write an object?
Mohanraj
In reply to Hi Mohan , by Kurumi
with GXDLMSDirector am able to read clock object. But unable to write clock object. I have already created another thread for this issue when using GXDLMSDirector .Access level is ReadWrite
Mohan Raj
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
