  3. Failed To Read Clock Object From Ciphered Meter
Failed to read clock object from ciphered meter
By Mohanraj , 30 April, 2020
We have now ciphered meter and trying to read clock object but failed.
below is the command and trace. Since there is no parameter for sending cipheredkey and authentication key i have modifed code as per below
/**************Added by Mohan for ciphered meter******************************************/
bb_clear(&con.settings.cipher.systemTitle);
bb_addString(&con.settings.cipher.systemTitle,"XXXXXXXX");
bb_clear(&con.settings.cipher.blockCipherKey);
bb_addString(&con.settings.cipher.blockCipherKey,"XXXXXXXXXXXXXXXXXXX");
bb_clear(&con.settings.cipher.authenticationKey);
bb_addString(&con.settings.cipher.authenticationKey,"XXXXXXXXXXXXXXXXXXX");
please rerfer the mail that i have shared yesterday for the keys
./bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -c 48 -s 1 -a High -P "0000000001035820" -C "AuthenticationEncryption" -g "0.0.0.1.0.255:1" -v "0.0.43.1.2.255" -t "Verbose" -I
updateInvocationCounter
RX: 7E A0 07 03 21 93 0F 01 7E 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 30 00 07 B2 6C 7E
TX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 02 FF 02 00 0E 7B 7E
RX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 02 FF 02 00 0E 7B 7E 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 81 00 06 AC 14 86 1C 77 0E 7E
Invocation counter: -1407941091 (0xFFFFFFFFAC14861D)
RX: 7E A0 07 03 21 53 03 C7 7E 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
InitializeConnection
TX: 7E A0 07 03 61 93 69 47 7E
RX: 7E A0 07 03 61 93 69 47 7E 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 86 1D 7E 8A 8F C8 43 B0 08 0C E2 F7 4F 78 8B F8 63 F3 59 A2 C4 E4 21 10 2C 01 61 54 51 43 7E
RX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 86 1D 7E 8A 8F C8 43 B0 08 0C E2 F7 4F 78 8B F8 63 F3 59 A2 C4 E4 21 10 2C 01 61 54 51 43 7EAARQRequest failed Send failed.
TX: 7E A0 07 03 61 53 65 81 7E
RX: 7E A0 07 03 61 53 65 81 7E 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
All items are read.
Mohan Raj
6 years 6 months ago
Hi Mohan ,
Hi Mohan ,
Please, don't create several topics from the same question. I believe that your client address is wrong.
Use US, not PUSH address.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
