  3. AARQRequest Failed Authentication Failed With Latest Stack
AARQRequest failed Authentication failed with latest stack
By Mohanraj , 30 April, 2020
Hi Miko,
Just now downloaded latest stack and compiled successfully. trying to read object but authentication failied. below is the trace
./bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -c 32 -s 1 -a Low -P "lnt1" -g "0.0.1.0.0.255:1" -t "Verbose"
InitializeConnection
TX: 7E A0 07 03 41 93 5A 64 7E
RX: 7E A0 1E 41 03 73 8E 7F 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 40 03 41 10 5F 93 E6 E6 00 60 32 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 06 80 04 6C 6E 74 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 39 24 7E
RX: 7E A0 2D 41 03 30 2E 66 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 06 04 04 0E 01 06 00 3D 0E 7E
AARQRequest failed Authentication failure.
TX: 7E A0 07 03 41 53 56 A2 7E
All items are read.
Mohan Raj
6 years 3 months ago
Can you connect with older version? Is your client address correct? Do you need to use ciphering?
Mohanraj
With older version it is working with same arguments. No Ciphering
Mohan Raj
Can you post the trace from the old one. We can't repeat your error.
Mohanraj
We are really sorry Mikko for the inconvenience. We have checked with just now the meter firmware team. they have confirmed that it is ciphered. I shall now try with ciphered arguments.
Mohan Raj
Hi Mohan,
Hi Mohan,
Don't worry. I was thinking that we haven't done any changes for that part, but it's always possible.
Thanks for letting me know.
  • test
  • RogerBar
  • NarayanDangi
  • jebNNbevKYNMITOUy
  • KadokTen
  • xMjAupjsfUDybB…
