  3. Token Generation Using Gurux Director
Token generation using Gurux Director
By nikunj.mitaleya , 20 April, 2020
We want to test payment objects (Account, Credit, Charge, and Token_Gateway) using Gurux Director and Server.exe.
In that initially, we are trying to generate a token from Gurux Director which will be transferred to server.exe for testing.
So, Can you please suggest an efficient way to generate a token from Gurux Director? and its further use?
6 years 5 months ago
Token depends on the meter. You need to contact the meter manufacturer on how token is generated.
nikunj.mitaleya
Thanks, Mikko for the reply.
That's fine, I need to contact the manufacturer to understand how the token is generated.
However, currently I am testing with Gurux's DLMS Server exe, and just wanted to know if there is any way to generate dummy Token for testing the flow from Gurux Director to DLMS Server exe.
I am trying to understand the Prepayment flow, can you please provide any help in that.
6 years 4 months ago
Current example server can receive token, but there is no business logic between token and account, credit or charge.
