  3. HDLC Parameters Settings In DLMS Protocol
HDLC parameters settings in DLMS protocol
By KhushbuBadheka , 10 April, 2020
As per the information related to HDLC frame settings, it shows that parameters like :
Max frame size in transmit
Max frame size in receive
Window size in transmit
Window size in receive
are only supported to IEC protocol.
However, I want to use them for DLMS meters to make frame size lesser. Or you can say
whether those parameters are applicable for DLMS frames that we need to send and receive?
Thanks and Regards,
6 years 5 months ago
You can set those values selecting Advanced-tab in GXDLMSDirector and modify HDLC settings.
OR:
GXDLMSClient cl = new GXDLMSClient();
cl.Limits.MaxInfoTX = cl.Limits.MaxInfoRX= 256;
KhushbuBadheka
Thanks Mikko,
Thanks Mikko,
As you suggested we already set HDLC settings using Advanced-tab in GXDLMSDirector. However, when we read IEC HDLC settings we got different values.
Please check the attached screen shots.
KhushbuBadheka
HDLC frame settiings.
HDLC setup shows default values. In the Advanced page, you set proposed values that the client proposes when making the connection. Note! All the meters don't support this.
Try to change max payload from 128 to 250 in Advanced page.
KhushbuBadheka
Thanks Mikko,
Thanks Mikko,
I tried to set required length and yes as per your suggestion it was set. However, when I tried to read Profile Generic, I received data more than set values.
Set Max length in TX/RX = 200
Received data length = 208
Regards.
TX/RX size is the size of payload, not size of the frame.
KhushbuBadheka
Noted.
Noted.
Mikko, Can you please help me to set the PDU size with which frame size will not be exceeded more than 200 bytes?
Regards.
Change max payload from 200 to 192 in Advanced page.
KhushbuBadheka
Thanks Mikko.
Thanks Mikko.
Will check and let you know.
Regards.
KhushbuBadheka
Thanks Mikko.
Thanks Mikko.
It Worked.
Stay safe.
