  3. Firmware Update Using GXDLMSDirector
Firmware Update using GXDLMSDirector
By Bhaumik , 25 March, 2020
We are currently testing firmware upgrade using GXDLMSDirector and Server EXE.
Using Example server EXE while we upload the image it is crashed. So is there any update in server code to upload the image?
Do you have any Test firmware file using which we can test full functionality?
6 years 5 months ago
What programming language you are using? The simple server doesn't actually update the image. It only transfers the image. You can use any image file you want to.
Bhaumik
I am using C# programming language.
I did try to update the image and it worked without problems. What kind of problem you have?
BR;
Bhaumik
I am using server of C programming language and updating image from GXDLMSDirector.
When I am updating image, Image is trasferred from GXDLMSDirector to server. After that server exe crashed and no further process happen.
Are you using malloc or it is ignored?
