  3. Set Meter Parameters By CF9
Set Meter Parameters by CF9
By walter , 18 March, 2020
Hi Mikko, All,
I'm having some troubles during setting meter at Object-CF9.
I tried to set CF9 by "CompactData->0.0.66.0.9.255" in GXDLMSDirector.
But only "Spare Object" reports a success. All other Obis reports an "UNMATCHED TYPE" and they cannot be set as I want.
Am I missing something and/or is there a different approach to make the trick?
Thanks in advance for your kind feedback.
Walter
6 years 6 months ago
Hi Walter,
Hi Walter,
Can you post commented trace here? If data is decrypted I can check what is wrong.
walter
thank you for the prompt reply.
Here the log trace:
10:36:36 Writing object 0.0.66.0.9.255, interface CompactData
7E A0 4A 03 03 10 27 3A E6 E6 00 DB 00 3B 30 00 00 00 01 7D 38 16 3C AF 82 E4 3C 6F 78 91 7E 14 7D 39 6A 1A A2 74 2E B6 49 97 CE 2D 17 F0 E9 BA 07 2B C8 CB CF 1E 28 17 85 E8 AC AE 4A D1 80 11 21 65 71 DC CD 12 7A B5 5D AF 38 7E
Please consider that trace is crypted. Below you can find CF9 decripted payload:
09 06 00 00 0A 00 6A FF 00 02 01 04 16 00 00 00 05 07 E4 03 02 02 00 00 FF FF 00
Thanks in advance.
Walter
Hi Walter,
Hi Walter,
Can you check "Comments" and "PDU" from "View" and "Trace"? Then you can see data as xml format.
Can you paste write output here?
walter
thanks for your reply. Below required logs:
Here PDU:
10:36:35
<Snrm>
</Snrm>
10:36:35
<Ua>
</Ua>
10:36:36
<GeneralGloCiphering>
<SystemTitle Value="" />
<CipheredService Value="30000000017D38163CAF82E43C6F78917E147D396A1AA2742EB64997CE2D17F0E9BA072BC8CBCF1E281785E8ACAE4AD18011216571DCCD127AB55D" />
</GeneralGloCiphering>
10:38:30
<CipheredService Value="300000000272D4CEFABAE09FA34515F3489809152F373490C8D147BFFFAB" />
Here Comments:
13:41:42
<!--Decrypt data: C1 01 C1 00 3E 00 00 42 00 09 FF 02 00 09 1B 09 06 00 00 0A 00 6A FF 00 01 01 04 16 00 00 FF 05 07 E4 03 04 03 00 00 FF FF 01
<SetRequest>
<SetRequestNormal>
<AttributeDescriptor>
<!--CompactData-->
<ClassId Value="003E" />
<!--0.0.66.0.9.255-->
<InstanceId Value="0000420009FF" />
<AttributeId Value="02" />
</AttributeDescriptor>
<Value>
<OctetString Value="090600000A006AFF00010104160000FF0507E40304030000FFFF01" />
</Value>
</SetRequestNormal>
</SetRequest>
<CipheredService Value="300000000559AA6B55DB59B6F87673C0093766448049B4DB8D07BE3B65581B929324ECAE8B1786AB2DC55639D427531F722820EFDED5651D1AF7E3" />
13:41:46
<!--Decrypt data: C5 01 C1 0C
<SetResponse>
<SetResponseNormal>
<Result Value="UnmatchedType" />
</SetResponseNormal>
</SetResponse>
<CipheredService Value="3000000019CB0E80300DEC641A37F69092F522F210" />
thanks and Regards,
Walter
walter
Hope you're very well.
Had you got the chance to take a look on the logs messages?
Thank you in advance.
Kind Regards,
Walter
walter
6 years 5 months ago
Hope this message will find you very well.
Have you got the chance to check logs? Any update on the task?
Thanks in advance.
