  3. ZMD With Multipoint
ZMD with multipoint
By dntimmie , 9 March, 2020
I connect to the meters via IP dlms (CU-L52 and CU-B2) and I get the message: No connection could be made because the target machine actively refused it.
What is the problem or what are the settings of both meters?
I use the serial numbers, but what do I do with physical address, logical address and useLogicalNameReferencing?
6 years 8 months ago
Your IP address or port number is wrong.
You don't set physical address If you are using serial number. Try to set useLogicalNameReferencing to true.
dntimmie
I checked the port number and
I checked the port number and IP. They are OK. useLogicalNameReferencing gives no solution.
dntimmie
I forgot: what are the
I forgot: what are the logical addresses of both meters?
This is TCP/IP issue. TCP/IP connection can't be established. Check firewall, etc...
DLMS settings don't affect to this error.
Are you using GPRS or direct TCP/IP?
http://www.gurux.fi/Gurux.DLMS.DynamicIP
dntimmie
I'm using direct TCP/IP. I
I'm using direct TCP/IP. I think I solved the problem. The meters were read out both on the exact same time. I have a main and check meter. I read out the check meter one minute later now.
