  3. Need Energy Meter Which Supports DLMS With Serial and TCP
Need Energy Meter which supports DLMS with Serial and TCP
By gkrishna , 18 February, 2020
Hi All,
We have started planning implementing DLMS support in our IOT device. IN order to test or experiment, we need DLMS support energy meter device and also it should support both TCP and serial as well.
Please suggest me some good products which I can buy.
Thanks in advance.
Gopi Krishna M
6 years 8 months ago
Hi Gopi,
Hi Gopi,
It's hard to say because I don't know the requirements or price that you want to pay.
I don't know what standard you want to support (India, Italy, Saudi Arabia, IDIS, etc).
gkrishna
Thanks for your reply.
As of now we are planning for India, The price is not an issue but It should support TCP, Serial(Rs232/Bluetooth).
The standard will vary for country to country? The underlying protocol will be same, and only the parameters in message transfer only will vary. Is not it?
There are substandard from DLMS, like in India IS 15959.
You can ask meters like this example from Genus or Crystal Power.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
