By mahsen , 12 February, 2020 Forums DLMSDirector Hi Why error when clicking the "IECLocalPortSetup" object in the new "DLMSDirector" update? Image Hi, Hi, Thanks from the info. I did try to repeat this but it worked without problems for me. We'll check this. BR, Mikko Hi, Hi, This is now fixed and tests are started. We'll release new version today. BR, Mikko Thank you too, Thank you too, Yes the problem was fixed. Hi, Hi, The problem was solved, but in the new update I saw an error again in clicking "IECLocalPortSetup" and "ProfileGeneric" !? Hi, Hi, Can you check your version and post it here? Select "About" from "Help" menu. BR, Mikko Ok. Ok. Image Hi, Hi, Can you update it to the latest version? There is a version 8.2.2002.1202. Let me know if you have any problems. BR, Mikko No, I Can not. Yes, Thank you.
We'll check this.
Thank you too,
Thank you too,
Ok.
Ok.
No, I Can not.
Yes, Thank you.
