  3. Reading L&T Energy Meter ER300p
Reading L&T energy meter ER300p
Profile picture for user gzpmanish
By gzpmanish , 5 February, 2020
I am used ER300p energy meter(L&T). It is a Indian Standard meter. I am used optical cable to read the dlms data using GXDLMSDirector.
I have get some data from the GXDLMSDirector. After some time, its given a error was fail to receive reply from the device in given time. I was not found data of KWh, KVArh and other. I have attached the screen shot below.
Same question ask the other person, you said Try to change the authentication level from None to low or High.How to find authentication password, I do not have any manual ?
Please help me, I am beginner in dlms.
6 years 7 months ago
I believe that you are right. You need to change the authentication level. You need to ask password from the meter vendor. It can be anything.
Reason why you are receiving failed to receive reply error is that there is an inactivity timeout on the meter.
Change inactivity timeout from the "Advanced" tab on the meter settings.
gzpmanish
Sir, I am try different
Sir, I am try different energy meter which is sumeru verde company. I given to high level authentication level, Its given a different error, I am attached screenshot of the error. What I doing wrong?
Your IP address is invalid. Check it.
gzpmanish
But I am used optical cable
But I am used optical cable (Serial) to read DLMS data.
Hi Manish,
Hi Manish,
TCP/IP is the default connection type. Change media to serial from device settings.
gzpmanish
I am attached the screenshot
I am attached the screenshot of the meter setting.
Hi Manish,
Hi Manish,
Does this error occur when you make the connection or when you try to read data from the meter?
What you try to read?
gzpmanish
When I am try to read data
When I am try to read data from the meter than its given a error?
What you try to read? I believe IP v4 address.
gzpmanish
Thanks a lot for your kind
Thanks a lot for your kind help.
When I update the your software its work.
rahul p
5 years 12 months ago
sir
sir
I want to read data from the ER300P energy meter using RJ11 port through arduino micro controller .
can you please help me with this how to go above ?
5 years 11 months ago
In reply to sir by rahul p
Hi Rahul,
Hi Rahul,
