  3. Error Reading Association View Landys+Gyr
Error reading Association View Landys+Gyr
By fdbailes , 30 January, 2020
Hello.
I'm trying to read Landis+Gyr Meter (ZMD405CT44.2407) as i did times before with older versions of gurux DLMS. Now I encounter error when i'm getting the association view.
I get the following error: Unacceptable Frame 3 times in a row and then it shows connected but no object list gets created as it was in previous versions.
If I hit refresh button the error is more specficic as: "GetObjects Failed: Unacceptable Frame"
I got the same behaviour with 3 different meters from the same brand and the exact same model.
These are the last lines of the trace.
RX: 7E A0 0C 21 03 97 3E 21 BA 88 08 0B F8 7E
12:27:05 Get profile generic columns...
TX: 7E A0 11 03 21 94 8B FD E6 E6 00 05 01 02 60 F0 F2 01 7E
12:27:05
RX: 7E A0 07 21 03 91 1D 84 7E
TX: 7E A0 11 03 21 B6 9B FF E6 E6 00 05 01 02 62 80 C5 41 7E
12:27:05
RX: 7E A0 0C 21 03 97 3E 21 B6 88 08 A8 5D 7E
12:27:12 Get profile generic columns...
TX: 7E A0 11 03 21 D8 E3 75 E6 E6 00 05 01 02 64 10 9C 81 7E
12:27:12
RX: 7E A0 0C 21 03 97 3E 21 D8 88 08 FE 48 7E
12:27:13 Reading object 0.0.22.0.0.255, interface IecHdlcSetup
TX: 7E A0 11 03 21 FA F3 77 E6 E6 00 05 01 02 2C E8 FD 72 7E
12:27:13
RX: 7E A0 0C 21 03 97 3E 21 FA 88 08 7D FE 7E
12:29:03 Send Keep Alive
TX: 7E A0 11 03 21 1C CB F5 E6 E6 00 05 01 02 FA 00 50 12 7E
12:29:03
RX: 7E A0 0C 21 03 97 3E 21 1C 88 08 05 21 7E
12:29:03 Disconnect request
12:29:03
RX: 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
any ideas?
Thank you.
6 years 7 months ago
Can you try to read a meter again and send the whole frame to me by email? We can check this.
fdbailes
In reply to Hello, by Kurumi
Of course I will try to
Of course I will try to connect again a save you the whole trace.
Just need to know to which email do I send you the log.
You can get my email address from here:
http://www.gurux.fi/AboutUs
fdbailes
Great Mikko.
Great Mikko.
I already sent you the full trace.
Let me know if I can be of further assistance.
Thanks in advance.
Federico.
Hi Federico,
Hi Federico,
This is fixed. Get the latest version from GXDLMSDirector.
fdbailes
In reply to Hi Federico, by Kurumi
Hi Mikko.
Hi Mikko.
Got the latest version and everything is working.
Problem is fixed.
Thanks again.
Federico
Hi Federico,
Hi Federico,
Thanks for the information.
