  3. Converting Read Object Into Readable Format
Converting read object into readable format
By Mohanraj , 11 January, 2020
Have followed ANSI C Client Example to read single object. But getting segmentation fault.
Please help.
gxData myobject;
cosem_init(&myobject.base,DLMS_OBJECT_TYPE_DATA,"0.0.96.1.0.255");
com_read(&con, &myobject.base, 2);
obj_toString(&myobject, &data); //Segmentation fault at this line
Below is the trace
TX: 7E A0 19 03 41 54 0A BB E6 E6 00 C0 01 81 00 01 00 00 60 01 00 FF 02 00 8C 6D 7E
RX: 7E A0 1A 41 03 74 DD 79 E6 E7 00 C4 01 81 00 09 08 39 30 38 33 34 35 31 37 E0 D6 7E
Mohan
Mohanraj
6 years 6 months ago
Hi Any update please?
This is now tested with several different PCs without problems.
Have you set data to NULL?
char* data = NULL;
gxData myobject;
cosem_init(BASE(myobject), DLMS_OBJECT_TYPE_DATA, "0.0.96.1.0.255");
com_read(connection, BASE(myobject), 2);
obj_toString(BASE(myobject), &data);
printf("%s\r\n", data);
If you have still problems let me know the compiler and environment that you are using.
Make sure that you have the latest version.
Mohanraj
data is not set to null.Thank
data is not set to null.Thank you.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
