  3. Changing Timeout For Opening The Connection
Changing timeout for opening the connection
By lrd2 , 12 December, 2019
I would like to change the timeout for opening the client connection with meter ( meterConnection.open() ). Is it possible?
Best wishes
Pietari
6 years 10 months ago
Hi Pietari,
Hi Pietari,
Is this GXDLMSDirector or client app? What programming language you are using?
lrd2
In reply to Hi Pietari, by Kurumi
It's a client app developed
It's a client app developed in Java.
Is this gurux.net.java component or something else that you are using?
lrd2
Yes, the connection is an
Yes, the connection is an object of class GXNet :)
At the moment it's coming from OS. I believe that you want to set custom value?
lrd2
Thank you for replying. Yes,
Thank you for replying. Yes, my intention was to set the custom value, I haven't known that it's coming from OS. Is it possible to set another value, or does it require changing whole Gurux library?
We also needed the same functionality with some of our tests. Get the latest version (1.0.20). You can set a connection wait time is you want to.
lrd2
That's great, thank you!
Shall it be available here: http://www.gurux.fi/gurux.net.java? I can see the information that new version has been released (1.0.20), but no download link is available.
It should be on the Central.
https://search.maven.org/artifact/org.gurux/gurux.net/1.0.20/jar
lrd2
You're right, I was searching
You're right, I was searching at mvnrepository.com where it wasn't available.
Method setConnectionWaitTime() on GXNet object, works great. Thank you :)
  • Eric@li
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
