  3. Problem With Sending Through GSM Modem
Problem with sending through GSM Modem
By DemoniKsataNa , 19 November, 2019
I have SL7000 meter and GSMModem iRZ. When i send by using RS-485 cable - everything work. But when i'm trying to use GSM modem i'm getting issues.
When i send SNRM like this:
7E A0 0A 00 22 00 51 03 93 6A 34 7E
I get normal UA.
But when i try to send SNRM like this:
7E A0 21 00 22 00 51 03 93 6B 21 81 80 12 05 01 80 07 04 00 00 00 02 08 04 00 00 00 01 3D 93 7E (It's from DXDLMSDirector)
I get nothing. Absolutely!
6 years 10 months ago
This message is not GXDLMSDirector or then you have modify the source code.
DemoniKsataNa
It's from GXDLMSDirector log.
It's from GXDLMSDirector log. I literally copied it to my program.
DemoniKsataNa
I figured out. It was my bad,
I figured out. It was my bad, I forgot to add one thing to my code for GSM modem.
I'm glad that your problem solved.
DemoniKsataNa
Thanks! You're so kind:-)
