  3. Urgent! Authentication High + Wrapper Combination
By pankaj1181998 , 15 November, 2019
We have our Gurux server(Example 2) up and running.We do have our Director.
Basically we are trying to connect to server with Authentication HIGH and Interface type as WRAPPER.
Password that we use is Gurux.But it is not connecting to the server with an error "Failed to get response"
Manufacturer : Indian Standard and Landis Gyr
PLease help!
6 years 11 months ago
If you are using WRAPPER make sure that port is 4063.
In the command line you should see this text:
Logical Name DLMS Server with IEC 62056-47 in port 4063.
pankaj1181998
It's working for low
It's working for low authentication with password "Gurux" but not for high . What about the high ??
High is working same way. Just set authentication to High.
pankaj1181998
It worked . Thanks for the
It worked . Thanks for the support .
  • Eric@li
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
