  3. Reading HXE Smart Meter Using Optical Head With Python
Reading HXE smart meter using optical head with python
By klem_ai , 11 October, 2019
Hello, I am trying to read from HXE energy meter using optical probe. From the documentation, the meter works with Protocol mode E. Is there a python Library i can use to get this done, and also do i need any information before i can read from it?
Currently when I send '/?!\r\n', I get '/HXE5\2HXE12' as reply from the meter. what do i need to do next?
raihb
7 years ago
It's Hexing meter?
It's Hexing meter?
klem_ai
7 years ago
In reply to It's Hexing meter? by raihb
Yes..... hxe310-kp .... Help!
7 years ago
Can you try to read your meter with GXDLMSDirector first? I'll help you to read it with python after that.
When you can read your meter with GXDLMSDirector I know that communication between the PC and the meter is working.
klem_ai
7 years ago
done!.. tried using NO/LOW
done!.. tried using NO/LOW authentication but i couldn't read the values. I was only able to read only using High authentication with password '00 00 00 00 00 00' . at least i want to read voltage and current and was able to do that. I now need to implement this high authentication setting and read out using either python or C/C++. I need help
Thank you,
7 years ago
Python is not support High authentication at the moment. We'll relese version at the end of this month that can read it. You can use ANSI C or ANSI C++ version.
Check the client example. It does what you want to do.
klem_ai
7 years ago
I have downloaded the ANSI C++ library, i ran make on the makefile in the development folder and it was successful, I also ran make in the GuruxDLMSClientExample folder after creating obj and bin directories.
Now, how can i run the GuruxDLMSClientExample.cpp file on a linux machine(Raspbian) ?
7 years ago
Executable is found from bin-folder. The command-line parameters are the same.
raihb
7 years ago
In reply to done!.. tried using NO/LOW by klem_ai
Hello, could you confirm me
Hello, could you confirm me what logical and physical address you used to Hexing meter
klem_ai
7 years ago
Thanks a lot. now i am
Thanks a lot. now i am getting passed the iec handshake, but afterwards i get "SNRMRequest failed 252". I am using a raspberry pi board
7 years ago
Did you change the client address and password?
klem_ai
7 years ago
I passed it in as command
I passed it in as command from terminal bin directory as >>
$./gurux.dlms.client.bin -i -S /dev/ttyUSB0 -a High -P "00 00 00 00 00 00" -t Verbose
it only got passed the iec handshake
7 years ago
You need to hard-code the password. It's handled as a string and your meter expects that it's hex string.
The client example can handle only strings at the moment.
klem_ai
7 years ago
The python update for high authentication, will it be available for use this month end? as you said
7 years ago
We are testing it at the moment.
7 years ago
There is a new version available from client example also in GitHub.
You can use High authentication like this:
-h localhost -p 4061 -a High -P Gurux
klem_ai
7 years ago
I am using optical probe to read from the meter. will this still work?
7 years ago
In reply to Hi, by klem_ai
Try to add -i parameter. It depends on the meter is IEC 62056-21 needed when connection is started.
Most European meters are using it, but several India or China meters are not used it.
klem_ai
6 years 12 months ago
hello kurumi,
hello kurumi,
i have tried the new python library update and even hard coded the password. and when i check the log file, it's not receiving anything yet. please help
above contain screen shots of the hard coded password part and also results from running
$ python3 main.py -i -S /dev/ttyUSB0 -a HIGH -P "00 00 00 00 00 00" and still yet nothing is received when i check the log file
klem_ai
code output
code output
pi@raspberrypi:~/Gurux.DLMS.Python-master/Gurux.DLMS.Client.Example.python $ python3 main.py -i -S /dev/ttyUSB0 -a HIGH -P '00 00 00 00 00 00'
password: 3030203030203030203030203030203030
Authentication: Authentication.HIGH
ClientAddress: 0x10
RX: 19:38:21
File "main.py", line 80, in main
reader.readAll()
File "/home/pi/Gurux.DLMS.Python-master/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 423, in readAll
self.initializeConnection()
File "/home/pi/Gurux.DLMS.Python-master/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 235, in initializeConnection
File "/home/pi/Gurux.DLMS.Python-master/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 91, in readDLMSPacket
File "/home/pi/Gurux.DLMS.Python-master/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 142, in readDLMSPacket2
raise e
File "/home/pi/Gurux.DLMS.Python-master/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 134, in readDLMSPacket2
raise TimeoutException("Failed to receive reply from the device in given time.")
gurux_common.TimeoutException.TimeoutException: Failed to receive reply from the device in given time.
klem_ai
This is the password hard
This is the password hard coded part
Your hard coded pasword is 3030203030203030203030203030203030.
It should be 00 00 00 00 00 00.
klem_ai
6 years 11 months ago
hello,
hello,
tried that two, noticed the -i doesn't flag the iec true, i had to hard code it and the initialization function is now being called. I don't receive any response when it sends "/?!\r\n", i get failed to receive media or something. I have tried so many combinations but i still havn't read from the meter. I can read it through GXDLMSDirector but i want to read it with python. I am using optical head via serial.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
