  3. I Got AARQRequest Failed 252
I got AARQRequest failed 252
By lofna , 24 October, 2019
I am using Sprint 350 established the connection via serial port and got the below
error.
InitializeConnection
AARQRequest failed 279.
cat trace.txt
TX: 18:06:48 7E A0 07 03 21 93 0F 01 7E
RX: 18:06:48 7E A0 20 21 03 73 73 98 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
TX: 18:06:48 7E A0 44 03 21 10 E6 84 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 30 30 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 1D 76 7E
RX: 18:06:48 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 0F 53 7E
TX: 18:06:48 7E A0 07 03 21 53 03 C7 7E
Without authentication i am getting the meter specific information which i have mentioned below the log.
./gurux.dlms.client.bin -S /dev/ttyUSB0 9600
GetAssociationView
-------- Reading GXDLMSAssociationLogicalName 0.0.40.0.0.255
Index: 2 Value: [0.0.40.0.0.255, 0.0.40.0.1.255, 1.0.0.0.6.255, 1.0.96.160.0.255, 1.0.0.0.1.255, 0.0.96.1.0.255, 0.0.42.0.0.255, 0.0.1.0.0.255]
Index: 3 Value: 16/1
Index: 4 Value: 0 0 0 5 8 1 1
Index: 5 Value: 16 512 1024 6 0
Index: 6 Value: 0 0 0 5 8 2 0
Index: 8 Value: 2
-------- Reading GXDLMSAssociationLogicalName 0.0.40.0.1.255
Index: 8 Value: 2
-------- Reading GXDLMSData 1.0.0.0.6.255
Index: 2 Value: 69.83.76.45.48.48.50
-------- Reading GXDLMSData 1.0.96.160.0.255
Index: 2 Value: {{1.0.1.8.0.255, 134}, {1.0.2.8.0.255, 133}, {1.0.5.8.0.255, 150}, {1.0.6.8.0.255, 152}, {1.0.7.8.0.255, 151}, {1.0.8.8.0.255, 149}, {1.0.9.8.0.255, 161}, {1.0.10.8.0.255, 165}, {1.0.1.128.0.255, 208}, {1.0.16.8.0.255, 240}}
-------- Reading GXDLMSData 1.0.0.0.1.255
Index: 2 Value: 77.50.88.55.71.48.67
-------- Reading GXDLMSData 0.0.96.1.0.255
Index: 2 Value: 73.80.76.68.48.49.55.48
-------- Reading GXDLMSData 0.0.42.0.0.255
Index: 2 Value: 69.72.76.69.51.68.120.120.120
-------- Reading GXDLMSClock 0.0.1.0.0.255
Index: 2 Value: 10/24/2019 18:22:56
When i am using authentication mode i am getting
AARQRequest failed 252.
What could be the issue, how can i over come this issue. Here i am using usb to serial cable (FTDI).
I am using Indian standard with this command failed: (./gurux.dlms.client.bin -S /dev/ttyUSB0 -c 20 -s 1 -a Low -P ABCD0001)
Lofna
6 years 9 months ago
You have to change client address. Now it's 0x10 and this is used when authentication is not used. Try to change it to 0x20.
lofna
Thanks for your suggestions. Now i am getting the meter information that get stored under Log file.
how can i read the specific parameters from this Gurux library calls. Parameters mean voltage, current, frequency, power factor values. because i am new to dlms.
Now i got the total registers data get logged under log file.
How can i retrieve the particular parameters to read and display in readable/understandable decimal format.i am running this under arm linux platform.
regards,
lofna
You need to know the object interface type and OBIS code. When you know this, you can read that value.
Something like:
CGXDLMSClock clock("0.0.1.0.0.255");
read(clock, 2);
clock.GetTime()
shgandhi
4 years 2 months ago
hi ,
hi ,
I am communicating meter with optical cable and using gurux c code, but i got this error please help.
sudo ./bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -c 16 -s 1
GetAssociationView
-------- Reading Object AssociationLogicalName 0.0.40.0.1.255
ReadObject failed AssociationLogicalName 0.0.40.0.1.255:7 Access Error : Device reports scope of access violated.
Failed to read object AssociationLogicalName 0.0.40.0.1.255 attribute index 7
ReadObject failed AssociationLogicalName 0.0.40.0.1.255:9 Access Error : Device reports a unavailable object.
Failed to read object AssociationLogicalName 0.0.40.0.1.255 attribute index 9
ReadObject failed AssociationLogicalName 0.0.40.0.1.255:10 Access Error : Device reports a unavailable object.
Failed to read object AssociationLogicalName 0.0.40.0.1.255 attribute index 10
ReadObject failed AssociationLogicalName 0.0.40.0.1.255:11 Access Error : Device reports a unavailable object.
Failed to read object AssociationLogicalName 0.0.40.0.1.255 attribute index 11
In reply to hi , by shgandhi
Hi shgandhi,
Hi shgandhi,
You need to create a new topic. I'll answer your question after you have created a new topic.
  • ArthurDaype
  • hirenec11mic
  • Yeyen
  • Virtual
  • joesa4
