  3. Gurux Python Library Parameters For Hex Meter
Gurux python library parameters for hex meter
By klem_ai , 18 October, 2019
I have been able to successfully read the meter with the parameters set as shown in the image below. I am now trying to read the meter using a raspberry pi and the gurux python library. how do i pass in the right parameters to get this to work.
klem_ai
6 years 9 months ago
readings i got from the meter
readings i got from the meter using the application. I want to use the python library to implement this, how to i pass the arguments to the main.py file from the terminal. I have tried and it hasn't been successful using the python library.
Python don't support High authentication at the moment. I'll add it to the worklist. We'll release new version next week.
klem_ai
Thank you.
Thank you.
Is there a C/C++ library that supports this at the moment?
Yes, All other programming language are supporting it.
klem_ai
Thank you!
Thank you!
  • ArthurDaype
  • hirenec11mic
  • Yeyen
  • Virtual
  • joesa4
