  3. Gurux Python Library Parameters For Hex Meter
Gurux python library parameters for hex meter
By klem_ai , 18 October, 2019
I have been able to successfully read the meter with the parameters set as shown in the image below. I am now trying to read the meter using a raspberry pi and the gurux python library. how do i pass in the right parameters to get this to work.
klem_ai
7 years 1 month ago
readings i got from the meter
readings i got from the meter using the application. I want to use the python library to implement this, how to i pass the arguments to the main.py file from the terminal. I have tried and it hasn't been successful using the python library.
7 years 1 month ago
Python don't support High authentication at the moment. I'll add it to the worklist. We'll release new version next week.
klem_ai
7 years 1 month ago
Thank you.
Thank you.
Is there a C/C++ library that supports this at the moment?
7 years 1 month ago
Yes, All other programming language are supporting it.
klem_ai
7 years 1 month ago
Thank you!
Thank you!
