  3. How Could I Get Time Format From a Particular Meter?
How could I get time format from a particular meter?
By pradson , 2 October, 2019
How could I get data-time format from a particular meter?
For example format like this: "dd/mm/yyyy hh:mm:ss"
Kindly suggest me asap.
Thanks & Regards,
Pradson
7 years 1 month ago
Hi Pradson,
Hi Pradson,
There is no time format on the meter. We are using the system time format to show date and time.
pradson
7 years 1 month ago
In reply to Hi Pradson, by Kurumi
Thanks a lot Mikko for reply.
Actually, I have two sample application to read "clock" or "profile-generic" object. The both application returns different time format. One returns [dd/mm/yyyy hh:mm:ss] format and another [mm/dd/yyyy hh:mm:ss] format. My system format is [dd/mm/yyyy hh:mm:ss].
Kindly suggest me what should do, to get same time format.
Thanks & Regards,
Pradson
7 years 1 month ago
Hi Pradson,
Hi Pradson,
I believe that those applications are not Gurux apps? If they are not, you must ask from the application vendor it is possible to change the date-time format.
  • Tb. Laris Jaya | WA 083148835648
