  3. How Could I Get Time Format From a Particular Meter?
How could I get time format from a particular meter?
By pradson , 2 October, 2019
How could I get data-time format from a particular meter?
For example format like this: "dd/mm/yyyy hh:mm:ss"
Kindly suggest me asap.
Thanks & Regards,
Pradson
6 years 11 months ago
Hi Pradson,
Hi Pradson,
There is no time format on the meter. We are using the system time format to show date and time.
pradson
In reply to Hi Pradson, by Kurumi
Thanks a lot Mikko for reply.
Actually, I have two sample application to read "clock" or "profile-generic" object. The both application returns different time format. One returns [dd/mm/yyyy hh:mm:ss] format and another [mm/dd/yyyy hh:mm:ss] format. My system format is [dd/mm/yyyy hh:mm:ss].
Kindly suggest me what should do, to get same time format.
Thanks & Regards,
Pradson
Hi Pradson,
Hi Pradson,
I believe that those applications are not Gurux apps? If they are not, you must ask from the application vendor it is possible to change the date-time format.
