  3. GXDLMSDirector Obis Management
By walter , 25 September, 2019
I'm using GXDLMSDirector to manage Italian Manufacturer OBIS.
In particular I'd to modify attributes values type.
For instance the law defines the OBIS attribute as:
value ::= structure {
a: double-long-unsigned
b: double-long-unsigned
c: double-long-unsigned
In the GXDLMSDirector, the obis attribute is:
<Array>
<UInt8 Value="0" />
<UInt8 Value="0" />
<UInt8 Value="0" />
</Array>
So, what I'm finding, it is how to update/modify values type, in this case from default value "uint8" to "unit32".
Could you please give some help on this? Thanks in advance.
7 years 1 month ago
Hi Walter,
Hi Walter,
Make sure that you have the latest version. Your version should be 8.2.1909.1601
This is the data what I received.
<Structure>
<UInt32 Value="1" />
<UInt32 Value="2" />
<UInt32 Value="3" />
</Structure>
If this is not what you are receiving ask meter manufacturer to check this.
walter
7 years 1 month ago
thank you for the prompt reply.
I updated to Version 8.2.1909.1601, but I still have same issue.
<Structure>
<UInt8 Value="0" />
<UInt8 Value="0" />
<UInt8 Value="0" />
</Structure>
Then I checked meter manufacture and the attribute is properly declared as Uint32.
Is there the chance to customize attribute from Director? In order to force types to Uint32, instead of current wrong Uint8.
If this is not the case, could you please help to suggest an alternative way to fix this?
Thanks in advance for your helpful support.
7 years 1 month ago
Hi Walter,
Hi Walter,
Can you select "View" | "Trace" | "PDU". Then read this object again and post reply XML from trace window to here.
walter
7 years 1 month ago
thanks a lot for the kind support. Here XML response:
09:53:24
<GeneralGloCiphering>
<SystemTitle Value="" />
<CipheredService Value="30000000045BD21D52A3D02246C42770A645901A5B1621E275BDD4487E2B" />
</GeneralGloCiphering>
09:53:25
<CipheredService Value="300000000482EEDD6F9C61F9D08864B0FB7695993B9F0C19275C3563B5" />
Walter
7 years 1 month ago
I'm sorry. I didn't remember that SystemTitle is empty in Italian standard.
Is this a pre-established connection?
walter
7 years 1 month ago
Yes, it's pre-estabilished connection.
7 years 1 month ago
I was wondering why you are not seeing XML data, but you should also select "View" | "Trace" | "Comments".
After that, you can see XML comments on the trace window. Can you post XML trace again with comments?
walter
7 years 1 month ago
Thanks a lot for your support. Here the XML:
13:58:36
<!--Decrypt data: C0 01 C1 00 01 00 00 5E 27 34 FF 02 00
<GetRequest>
<GetRequestNormal>
<AttributeDescriptor>
<!--Data-->
<ClassId Value="0001" />
<!--0.0.94.39.52.255-->
<InstanceId Value="00005E2734FF" />
<AttributeId Value="02" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
<CipheredService Value="3000000001D39DD6A28B50C81BC0A8BADA1F9C7C8B2E39922167B2D56F7E" />
13:58:36
<!--Decrypt data: C4 01 C1 00 02 03 11 3C 11 14 11 78
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<Structure Qty="03" >
<UInt8 Value="3C" />
<UInt8 Value="14" />
<UInt8 Value="78" />
</Structure>
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
<CipheredService Value="3000000001F8D93E7ECA9BAD6CF5E20E25F776820FDEE71E721AF4111A" />
7 years 1 month ago
Hi Walter,
Hi Walter,
As I told before data is coming in the wrong format from the meter. Ask them to fix it.
This is raw data coming from the meter without encryption:
http://www.gurux.fi/GuruxDLMSTranslator?pdu=C401C1000203113C11141178
7 years 1 month ago
If they are saying that meter is sending correct data, ask them to count bytes in the reply message.
walter
7 years 1 month ago
I asked to fix the meter and now it seems to work properly.
Thank you for the great support. See you soon.
7 years 1 month ago
Hi Walter,
Hi Walter,
Thanks for the information. I'm glad that this is solved.
