By Javi_iGrid , 6 September, 2019 Forums DLMSDirector Trying to connect to a CLOU device using HIGH GMAC authentication, we're getting an "ServiceError Initiate Error exception. Inititate Other" message. We've setup the device as shows its user manual. Here I copy the hex traces that the application prints on the connect command: 11:55:51 Send SNRM request. TX: 7E A0 0A 00 02 00 21 03 93 23 D4 7E 11:55:51 RX: 7E A0 23 03 00 02 00 21 73 70 7B 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E 11:55:51 Send AARQ request. TX: 7E A0 84 00 02 00 21 03 10 8C 62 E6 E6 00 60 73 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 00 00 00 00 00 00 00 00 A9 03 02 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 75 57 02 51 0F 34 40 38 79 73 39 6E 72 07 25 42 BE 34 04 32 21 30 30 00 00 00 00 33 E9 DF B8 A2 F0 2D 1A D8 CF C8 18 31 D9 AE 19 51 18 2C 3C B8 67 26 A1 75 27 8F BE 76 37 E9 4A 9E A4 95 6D A2 28 D2 18 64 1C 01 86 C3 7E 11:55:52 RX: 7E A0 39 03 00 02 00 21 30 71 57 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 89 07 60 85 74 05 08 02 05 BE 06 04 04 0E 01 06 00 07 58 7E 11:55:52 RX: 7E A0 23 03 00 02 00 21 73 70 7B 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E Any help showing where should be the problem will be appreciated. Hi, Hi, You are using ciphering (encryption). Set security level to None. If you are using GXDLMSDirector you find it from "Security Settings" tab. BR, Mikko
