  3. Profile Generic - Python
Profile generic - Python
By frato , 23 August, 2019
Hello, first of all I want to thank you for your work is really amazing.
I have managed to read the records of an actaris meter. But what interests me most is to read a record of the 'Profile Generic' 0.1.98.1.0.255.
I am using Python 3.7.
If you could tell me how reading these records would be, I would appreciate it.
I tried with
GXDLMSProfileGeneric ()
and with readRowsByEntry ()
but I haven't got much
To read this record in 'GXDLMSDirector' I achieve it with read 1 count: 1
Getting the data I need
Thank
6 years 10 months ago
SL 7000 and ACE6000 are older meters and they don't support DLMS well with profile generics.
I can't remember if they support readRowsByEntry or readRowsByRange.
If there is only one row you can read it like this:
pg = GXDLMSProfileGeneric("0.1.98.1.0.255")
#Read capture objects first.
client.read(pg, 3);
#Read all rows from the buffer.
client.read(pg, 2);
frato
thanks for your time.
when using the functions you passed me I get:
[bytearray(b'~\xa0\x1a\x02#\x03>\x19\xa8\xe6\xe6\x00\xc0\x01\xc1\x00\x07\x00\x01b\x01\x00\xff\x02\x00\x15\x93~')]
Do you think the result is correct?
Should I process it to get the data?
I thought the result was a matris
thanks
This is Get request.
http://www.gurux.fi/GuruxDLMSTranslator?pdu=c001c100070001b0100ff020015…
Send this to the meter and meter reply to you.
frato
6 years 9 months ago
Thank you for your time.
I don't get the results when I do this I get:
gurux_dlms.GXDLMSException.GXDLMSException: Access Error : Unknown error.
Maybe I could give an example of reading the data I need.
I propose you to place an ACE6000 meter so that you can access it from the internet, to formulate the example, and if it helps you to acquire experience or try something.
I attached a photo of what I want to get, obtained from the GXDLMSDirector
Connection data is passed to you as private. I'll even give you an example of a date reading
thanks
frato
Hello, sorry for this message
Hello, sorry for this message, I have sent you the mail, but I have not received a reply, I assume that you have not seen it, or that I entered the spam box, I just resent it now.
thank you,
and a great respect for the work they do that is excellent
