  3. Bug In GXXmlWriter (java)
Bug in GXXmlWriter (java)
By bleg , 10 June, 2019
Methods:
writeElementString(final String name, final int value)
writeElementString(final String name, final long value)
writeElementString(final String name, final boolean value)
incorrectly check for value != 0 or value is true.
those values are not written into XML in case when check fails.
Though these values can legally be equal to 0 or false.
This is particulary results in missing data when saving objectcs of GXDLMDisconnect
if following attributes have inital values:
outputState = false
controlState = 0.
7 years 4 months ago
This is by design. Default values are not serialized to minimize file size. Do you need to save all the values? Let me know and we can add IgnoreDefaultValues property to GXXmlWriter.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
