  3. Dlms Program :Error Compiling For Arduino Board
dlms program :Error compiling For arduino board
By mnvasani , 7 June, 2019
hello , gurux
when i compile the program in arduino at that time this type of error show in the error box.
error:
Arduino: 1.8.9 (Windows 7), Board: "Arduino/Genuino Uno"
In file included from sketch\src\GXAPDU.cpp:35:0:
c:\users\admin\appdata\local\temp\arduino_build_777380\sketch\include\gxapdu.h:38:18: fatal error: vector: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
please give me the solution of this type error ,
thank you!
7 years 3 months ago
You need to copy include src folders from development folder to target directory where server.ino file is.
mnvasani
thanks for your fast response
thanks for your fast response.
I have done what you suggest as per your previous reply. but after that I compiled the program in arduino but again another errors are occur in the error box.
look error:
C:\Users\Admin\Desktop\GuruxDLMS.c-master\Arduino_IDE\server\server.ino: In function 'void loop()':
C:\Users\Admin\Desktop\GuruxDLMS.c-master\Arduino_IDE\server\server.ino:435:61: warning: invalid conversion from 'char*' to 'unsigned char*' [-fpermissive]
if (svr_handleRequest2(&settings, tmp, available, &reply) != 0)
In file included from C:\Users\Admin\Desktop\GuruxDLMS.c-master\Arduino_IDE\server\server.ino:38:0:
sketch\include/server.h:54:9: note: initializing argument 2 of 'int svr_handleRequest2(dlmsServerSettings*, unsigned char*, short unsigned int, gxByteBuffer*)'
sketch\src\bytebuffer.c:246:5: error: redefinition of 'bb_setUInt8ByIndex'
int bb_setUInt8ByIndex(
sketch\src\bytebuffer.c:210:5: note: previous definition of 'bb_setUInt8ByIndex' was here
sketch\src\bytebuffer.c: In function 'bb_setUInt8ByIndex':
sketch\src\bytebuffer.c:252:15: warning: implicit declaration of function 'bb_allocate' [-Wimplicit-function-declaration]
int ret = bb_allocate(arr, index, 1);
sketch\src\notify.c: In function 'notify_parsePush':
sketch\src\notify.c:242:43: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
arr_push(items, key_init(obj, (void*)(unsigned long long)index));
exit status 1
CAN YOU GIVE ME THE WITHOUT ERROR FILE OF ARDUINO PROGRAM ?
lot a thanks for your previous response.
MN VASANI..
Get the latest version from GitHub. Open gxignore.h and uncomment all the functionality that you don't need. It saves a lot of flash memory.
