  3. SAPHIR Meters In France
SAPHIR meters in France
By andres , 23 May, 2019
Hello everyone,
I'm trying to read data from the new SAPHIR counters installed by ENEDIS on different production and consumption sites in France
Does anyone have experience working with this kind of technology? I'm trying to manually create the Manufacturer and OBIS Code configuration to access them, but there are some things that I'm not sure how to configure, specially authentication using the "clé client".
Thanks!
andres
7 years 5 months ago
I've managed to configure the
I've managed to configure the meter in GXDLMSDirector.
Now I'm having a problem with authentication, but I don't understand where the problem is. The algorithm should be SHA-256, but the message "Connection is premanently rejected. Authentication mechanism name not recognised"
18:22:06
<HDLC len="22" >
<TargetAddress Value="4010" />
<SourceAddress Value="3" />
<!--SNRM frame.-->
<FrameType Value="93" />
<PDU>
<Snrm>
<MaxInfoTX Value="256" />
<MaxInfoRX Value="256" />
<WindowSizeTX Value="1" />
<WindowSizeRX Value="1" />
</Snrm>
</PDU>
</HDLC>
18:22:06
<HDLC len="22" >
<TargetAddress Value="3" />
<SourceAddress Value="4010" />
<!--UA frame.-->
<FrameType Value="73" />
<PDU>
<Ua>
</Ua>
</PDU>
</HDLC>
Duration: 301
18:22:06
<HDLC len="4E" >
<!--AARQ frame.-->
<FrameType Value="10" />
<PDU>
<AssociationRequest>
<MechanismName Value="HighSHA256" />
<CallingAuthentication Value="4C5D585F6924523C214C1377673B400E" />
<InitiateRequest>
<ProposedConformance>
<ConformanceBit Name="Set" />
<ConformanceBit Name="Get" />
<ConformanceBit Name="Attribute0SupportedWithGet" />
</ProposedConformance>
<ProposedMaxPduSize Value="0400" />
</InitiateRequest>
</AssociationRequest>
</PDU>
</HDLC>
18:22:06
<HDLC len="51" >
<!--AARE frame.-->
<FrameType Value="30" />
<PDU>
<AssociationResponse>
<!--PermanentRejected-->
<AssociationResult Value="01" />
<ResultSourceDiagnostic>
<!--AuthenticationMechanismNameNotRecognised-->
<ACSEServiceUser Value="0B" />
</ResultSourceDiagnostic>
<RespondingAuthentication Value="80AA12801080AA12801080AA12801080" />
<InitiateResponse>
<NegotiatedConformance>
</NegotiatedConformance>
<NegotiatedMaxPduSize Value="0400" />
<VaaName Value="0007" />
</InitiateResponse>
</AssociationResponse>
</PDU>
</HDLC>
Duration: 435
18:22:07
<HDLC len="C" >
<!--UA frame.-->
<Ua>
</Ua>
</HDLC>
Duration: 199
andres
I think I found the correct
I think I found the correct settings for authentication. The meter seems to respond OK to the request, but a .net error appears at some point "The destination table was not long enough. Check the destindex and the length and the lower limits of the table"
Here is the log:
14:15:03
<HDLC len="22" >
<!--SNRM frame.-->
<PDU>
<Snrm>
</Snrm>
</PDU>
</HDLC>
14:15:03
<HDLC len="22" >
<!--UA frame.-->
<PDU>
<Ua>
</Ua>
</PDU>
</HDLC>
Duration: 295
14:15:03
<HDLC len="4E" >
<!--AARQ frame.-->
<PDU>
<MechanismName Value="High" />
<CallingAuthentication Value="4963581E274E0C3079170024142C671C" />
<InitiateRequest>
</InitiateRequest>
</PDU>
</HDLC>
14:15:04
<HDLC len="74" >
<!--AARE frame.-->
<PDU>
<AssociationResult Value="00" />
<!--AuthenticationRequired-->
<ACSEServiceUser Value="0E" />
<RespondingAuthentication Value="FD5722C605E0135087EA258FA0775EBBD9C9EF7CA1A0CE16D0EFE4FAFA67B0F9BDC9B8C2AACA1333AE2F" />
<InitiateResponse>
</InitiateResponse>
</PDU>
</HDLC>
Duration: 570
andres
And sometimes, without doing
And sometimes, without doing anything in particular (just retrying), I obtain this, followed by an error "Meter returns Service unknown exception. Operation not possible"
14:37:26
<HDLC len="22" >
<!--SNRM frame.-->
<PDU>
<Snrm>
</Snrm>
</PDU>
</HDLC>
14:37:27
<HDLC len="22" >
<!--UA frame.-->
<PDU>
<Ua>
</Ua>
</PDU>
</HDLC>
Duration: 309
14:37:27
<HDLC len="4E" >
<!--AARQ frame.-->
<PDU>
<CallingAuthentication Value="4B33006C04202018025E230239401129" />
<InitiateRequest>
</InitiateRequest>
</PDU>
</HDLC>
14:37:27
<HDLC len="57" >
<!--AARE frame.-->
<PDU>
<RespondingAuthentication Value="61F1E550779F7C7D6E4BF999A7" />
<InitiateResponse>
</InitiateResponse>
</PDU>
</HDLC>
Duration: 468
14:37:27
<HDLC len="2D" >
<FrameType Value="32" />
<PDU>
<ActionRequest>
<ActionRequestNormal>
<MethodDescriptor>
<!--AssociationLogicalName-->
<ClassId Value="000F" />
<!--0.0.40.0.0.255-->
<InstanceId Value="0000280000FF" />
<MethodId Value="01" />
</MethodDescriptor>
<MethodInvocationParameters>
<OctetString Value="733E7552ABF67EA9F111893705A1F0F7" />
</MethodInvocationParameters>
</ActionRequestNormal>
</ActionRequest>
</PDU>
</HDLC>
14:37:28
<HDLC len="11" >
<FrameType Value="52" />
<PDU>
<Data="0201" />
</PDU>
</HDLC>
Duration: 291
Can you generate those errors and send the log file to me by email?
I'll check what meter is returning by bytes and is there anything that we can improve or is meter data simply invalid.
You can get my email address here:
https://www.gurux.fi/AboutUs
andres
Hello, which is the log file
Hello, which is the log file you need?
Read your meter. Then in GXDLMSDirector select "View" | "Log" | "View Log". Can you send this file to me by email?
I have checked the data that meter returns. It seems that the meter can't handle client challenge.
The first step is working like should be. The second step will fail.
Can you ask what high authentication level meter supports?
I believe that challenge is ciphered using the wrong encryption and for this reason, meter can't establish the connection.
andres
The meter specification
The meter specification indicates the following:
The authentication mechanism used is a HLS (4-phase authentication) mechanism according to document [4], with a SHA-256 encryption algorithm instead of the standard algorithms (MD5 and SHA-1) provided in this document [4]. The client authentication key ("client key" provided by Enedis) is OCTET STRING type 16 bytes. The challenge size used for this authentication phase is between 8 and 64 bytes. The authentication mechanism, as defined by the "authentication_mechanism_name" attribute of the association object, is: OCTET STRING (SIZE (7)) = {0x60, 0x85, 0x74, 0x05, 0x08, 0x02, 0x02} ;
But when I use SHA256 I get "Connection is permanently rejected. Authentication mechanism name not recognised."
In your trace file authentication is High (2), not SHA-256. Change your authentication to HighSha256. If you don't see it, change the manufacturer to Gurux and update other values.
