  3. Unable To Connect
unable to connect
By vslab , 13 April, 2019
unable to connect to the meter iskraemeco am550 via usb-optic adapter. help
vslab
7 years 3 months ago
what am I doing wrong?
Change "Start Protocol" from DLMS to IEC.
vslab
Yes. I did it like this. no
Yes. I did it like this. no positive results.
log dlms:
14:00:22 Initializing serial connection.
14:00:23 Send SNRM request.
7E A0 08 02 23 C9 93 E4 43 7E
14:00:28 Failed to receive reply from the device in given time.
14:00:28 Disconnect request
14:00:28 Send Disconnect request.
7E A0 08 02 23 C9 53 E8 85 7E
14:00:33 Failed to receive reply from the device in given time.
log iec:
14:02:01 Initializing serial connection.
14:02:02 HDLC sending:/?!<CR><LF>
14:02:12 Failed to receive reply from the device in given time.
vslab
No answer. Maybe it's in the
No answer. Maybe it's in the optician-usb converter? what is needed? on which chip?
vslab
Do you get to connect to
Do you get to connect to Israemeco am550?
vslab
Can there isrameko something
Can there isrameko something changed in the start-protocol?
my converter on FT232
What optical head you are using? Your meter is supporting DLMS and our customers read them but do not use an optical port. Check your optical head and make sure that it's using correct modulation (IEC 65056-21).
vslab
62056-21?
62056-21?
vslab
do you use what?
do you use what?
We have several different optical heads. Cheap ones are causing problems. ANSI heads don't work with DLMS meters. If you want to make it work right away, buy head from Kamstrup. It's working very well with different meters.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
