  3. How To Read DLMS Without Using GXNet Nor GXSerial
How to read DLMS without using GXNet nor GXSerial
By khun_panya , 5 April, 2019
This page https://github.com/Gurux/Gurux.DLMS.Net
says that Gurux.Net nor Gurux.Serial is not necessary.
But the examples have extensively used GXSerial and GXNet.
How can we implement ReadDLMSPacket method by using just simple TcpClient ?
Please show some example. Thanks.
khun_panya
7 years 5 months ago
OK. Here is my progress. I write a sub
private static byte[] SendAndReceive(TcpClient net, byte[] command)
var ns = net.GetStream();
ns.Write(command, 0, command.Length);
System.Threading.Thread.Sleep(100);
var buff = new byte[1024];
using (var ms = new System.IO.MemoryStream())
int len;
while (ns.DataAvailable)
len = ns.Read(buff, 0, buff.Length);
ms.Write(buff, 0, len);
return ms.ToArray();
And here is my main program
var net = new TcpClient();
net.Connect("xxx.xxx.xxx.xxx", 6001); // Landis+Gyr meter
var client = new GXDLMSClient();
client.UseLogicalNameReferencing = false;
client.InterfaceType = InterfaceType.HDLC;
client.ServerAddress = 1;
client.ClientAddress = 16;
var send = client.SNRMRequest();
var recv = SendAndReceive(net, send);
client.ParseUAResponse(new GXByteBuffer(recv));
But now the problem is ParseUAResponse throws GXDLMSException("Invalid Exception.").
Why is that? Lines below are send and recv binary.
7E A0 07 03 21 93 0F 01 7E
7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
Your code looks good and your settings are correct. What version from gurux.dlms.java you are using?
I just tested this and it worked like should be. I was using the same settings that you are.
Check what is reply data in new GXByteBuffer(recv).
khun_panya
I'm using latest Gurux.DLMS for C# v8.5.1904.401. Downloaded from NuGet.
It looks like the exception was thrown because the 5th byte of GXByteBuffer data was 03
which is not listed in switch-case within GXDLMS.ParseSnrmUaResponse(…).
Now I believe what it the reason. Before you call ParseUAResponse you need to call GetData.
client.GetData(recv, reply);
client.ParseUAResponse(reply.Data);
khun_panya
That works perfectly! Thank
That works perfectly! Thank you!
balaramjenagate
while I am running Gurux
while I am running Gurux.Serial.Android Master android app error: cannot find symbol method getPorts() is coming
In reply to while I am running Gurux by balaramjenagate
When you have new question, please, create a new topic. Have you imported serial port in to your android app? What version you are using from Android Studio?
