  3. Gurux.DLMS.Client.Example.VB Unacceptable Frame.
Gurux.DLMS.Client.Example.VB Unacceptable frame.
By jediace , 27 March, 2019
I have this error "Unaccemptable frame"
I use VS 2017 vb.net window 10
Landis+Gyr COM4 DLMS
in GXDLMSDirector i can connect and i read all values:
http://www.gurux.fi/sites/default/files/styles/thumbnail/public/forum/L…
in cmd prompt:
<p>C:\Users\Mondo Idro\Desktop\TEST CONTATORE>Gurux.DLMS.Client.Example.VB.exe /m=lgz /sp=COM4 /s=DLMS
Initializing serial connection.
Parsing UA reply succeeded.
Parsing AARE reply succeeded.
Get available objects from the device.
Disconnecting from the meter.
Unacceptable frame.
</p>
<p>
TRACE.TXT
<- 09:01:55 7E A0 07 03 21 93 0F 01 7E
-> 09:01:55 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
<- 09:01:55 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF 80 AB 7E
-> 09:01:55 7E A0 37 21 03 30 6C 7C E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 0F 04 0D 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 0A A8 7E
<- 09:01:55 7E A0 11 03 21 10 A7 3F E6 E6 00 05 01 02 FA 08 18 9E 7E
-> 09:01:56 7E A0 0C 21 03 97 3E 21 10 22 08 29 D6 7E
<- 09:01:56 7E A0 07 03 21 53 03 C7 7E
-> 09:01:56 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
</p>
I try:
<p>
C:\Users\Mondo Idro\Desktop\TEST CONTATORE>Gurux.DLMS.Client.Example.VB.exe /u
C:\Users\Mondo Idro\Desktop\TEST CONTATORE>Gurux.DLMS.Client.Example.VB.exe /m=lgz /sp=COM4 /s=DLMS /a=None
Unacceptable frame.
C:\Users\Mondo Idro\Desktop\TEST CONTATORE>Gurux.DLMS.Client.Example.VB.exe /m=lgz /sp=COM4 /s=DLMS /a=None /pw=*****
Unacceptable frame.
C:\Users\Mondo Idro\Desktop\TEST CONTATORE>Gurux.DLMS.Client.Example.VB.exe /m=lgz /sp=COM4 /s=DLMS /a=Low /pw=*****
Connection is permanently rejected. Authentication failure.
C:\Users\Mondo Idro\Desktop\TEST CONTATORE>Gurux.DLMS.Client.Example.VB.exe /m=lgz /sp=COM4 /s=DLMS /a=High /pw=****
Unacceptable frame.
C:\Users\Mondo Idro\Desktop\TEST CONTATORE>Gurux.DLMS.Client.Example.VB.exe /m=lgz /sp=COM4 /s=DLMS /a=High /pw=**** /client=12
Unacceptable frame.
C:\Users\Mondo Idro\Desktop\TEST CONTATORE>Gurux.DLMS.Client.Example.VB.exe /m=lgz /sp=COM4 /s=DLMS /pw=**** /client=16
Unacceptable frame.
C:\Users\Mondo Idro\Desktop\TEST CONTATORE>Gurux.DLMS.Client.Example.VB.exe /m=lgz /sp=COM4 /s=DLMS /pw=**** /client=16 /server=1
Unacceptable frame.
</p>
the log.txt file is empty
7 years 4 months ago
Hi jediace,
Hi jediace,
I check this and example was using very old version from Gurux.DLMS.Net component. I updated it to the GitHub. Get the latest version from there or you can update it by your self.
Select project and settings and select "Manage NuGet Packages". Update example to use the latest version.
  • SkyCrown
  • AllenGaugh
  • Kennetharrem
  • Brandonitaro
  • dermida
