  3. Secure Premier 300 RS232 Pinout Request
By jk96 , 2 September, 2018
Hello every one I am trying to connect Secure Premier 300 using RS232 & GXDLMSDirector the meter has a RJ11connector. so if someone have a pinout will be really helpfull.
7 years 11 months ago
If I remember right that information is on the user manual. Try to check it from there.
Note that RS232 and RS485 connectors are on different place.
jk96
In reply to Secure Premier 300 RS232 Pinout Request by Kurumi
hi thanks for the fast
hi thanks for the fast response i went through the available manuals and there is no pinout info.
The RJ11 on Left side is RS232 and RS485 on the Right side. my meter has a Left RJ11 connector so it is a RS232 and the meter label says Additional comms: RS 232 "DLMS COMPLIANT METER".
Try to google RJ11. It should be a standard PIN order.
jk96
I tried so many connections and all failed . I am using USB to RS232 converter with DB9
The meter has a 4 pin RJ11 connector for RS232.
I suggest that you get USB to RS232 where is the RJ11 connection. You have an adapter and it is causing sometimes problems.
  • xyBvBjRVwiYVQggL
  • RobertCon
  • JamesLef
  • Bryoneverb
  • vGYWbHeKACYPlTkuxT
