  3. Unable To Connecto To Elster A1052+
unable to connecto to Elster A1052+
By alkimer , 19 August, 2018
Hi !
I am trying to connecto to an Elster A1052+ via USB probe with no success, I have tried lots of configuration.. According to its specifications its maux baud rate is 2400 , and its IRDA port is IEC 62056-61 compliant..
I always receive "Failed to receive reply from the device in given time.";
If someone has any hints, it will be highly appreciated
best regards
7 years 9 months ago
What server address you are using? Try to select IEC as start protocol. Don't change anything. Just select IEC and try.
