  3. How To Convert Obis Code To Pdu Hex String
How to convert obis code to pdu Hex string
By karlpy , 22 June, 2018
When I copy and paste a request from GXDLMSDirector, I get an XML. The only thing that seems to change is this string <InstanceId Value="01000F0800FF" />
I'm building an application where I can select, or build reading profiles from any obis code in a database and make custom dlms requests. My question is, how can I convert an obis code, for example: 1.0.15.8.0.255 --> 01000F0800FF
or
1.0.5.8.0.255 --> 0100050800FF
in c# or in GXDLMSTranlator and vice versa?
If I can do that then I can generate an xml and don't need to create and save hundreds of xml files in my database. I'd appreciate suggestions about alternative solutions to this problem. As I said, I need my users to be able to dynamically create dlms-request-profiles which my program then is able to read.
8 years 1 month ago
Convert values to hex and skip dot's. Lie this:
1:0x01
0:0x00
5:0x05
8:0x08
0:0x00
255:0xFF
Adil Hameed
5 years 9 months ago
Hi sir!
Hi sir!
sir I have a device iskrameco mt880 I am not able to read it with general OBIS codes using serial port R232
my question is that can we read OBIS codes in the meter firmware.?
please help me
If you use GXDLMSDirector it will read association view and association wive will describe all the OBIS codes that meter can offer.
Adil Hameed
5 years 8 months ago
Dear sir ! I have its own
Dear sir ! I have its own software provided by the company iskrameco now I can read and write parameters.
Dear sir i want to know the obis code of (calibration measuring constant) There i have a obis code of (pulse constant 0.3.0, 0.3.1 etc) I want to change measuring constant with respect to my project!
Plz help
Dear Sir,
Dear Sir,
You need to ask this from the meter manufacturer. You can see all the OBIS codes and their descriptions in the application.
  • rcprociG
  • helloworld
  • Kak_nvKr
  • Geraldtup
  • Kak_jhKr
