  3. Message Encryption KeK Master Key Structure
By Gilmond , 18 April, 2018
OBJECTIVE: Understand how to construct a DLMS KeK (Key Encryption Key) and Data to be encrypted and decrypted.
SYNOPSIS:
The Gurux.DLMS library features GXDLMSSecureClient component which publishes an Encrypt and Decrypt method.
Each method takes two parameters:
Encrypt(byte[] kek, byte[] data)
Decrypt(byte[] kek, byte[] data)
GXDLMSSecureClient.Encrypt(KeK, MyData);
GXDLMSSecureClient.Decrypt(KeK, MyData);
QUESTION:
What is the KeK and how do I construct it?
8 years 1 month ago
Key Encrypting Key
KEK is Key Encrypting Key, also known as master key. It's 16 bytes long key that is used when you update keys.
Gilmond
8 years 1 month ago
How do I construct the KeK
How is the KeK derived?
We are trying to decrypt the 'additional encrypted message attributes' returned by the smart meter.
I think Attributes marked as encrypted should be decrypted using the KeK. But not sure how the KeK is derived.
