  3. I Got AARQ Failed.
I got AARQ failed.
By scron123 , 15 March, 2018
I got a DLMS/COSEM-based meter for academic research.
When I tried using "Gurux.DLMS.cpp" to make communication with my meter, I got AARQ failure.
Here is what I saw on raspberry console:
pi@raspberrypi:~/Gurux.DLMS.cpp/GuruxDLMSClientExample/bin $ ./gurux.dlms.client.bin -S /dev/ttyS0
InitializeConnection
AARQRequest failed -3.
pi@raspberrypi:~/Gurux.DLMS.cpp/GuruxDLMSClientExample/bin $ cat trace.txt
<- 07:07:05 7E A0 07 03 21 93 0F 01 7E
-> 07:07:05 7E A0 07 21 03 73 01 40 7E
<- 07:07:05 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
-> 07:07:05 7E A0 0C 21 03 97 3E 21 10 00 01 6B 5B 7E
According to meter's document,it is saying that:
"This meter doesn't accept I-frame in HDLC control field,and meter suggest using U-frame."
So, my question is :
"Could I change the control field from I-frame(0x10) to UI-frame(0x13) by some instruction or command?"
Administrator
8 years 6 months ago
I got AARQ failed.
Your client or server address is wrong. What meter are you trying to read?
scron123
I got AARQ failed.
Hi, Gurux Administrator
My meter is made by Taiwan Power Company.
I spent some time on attempt to figure out how to change the control field.
fortunately, I did it.Here is my solution:
1)Open the file "GXDLMS.cpp".(~/Gurux.DLMS.cpp/development/src/GXDLMS.cpp)
2)In the line:821, there is a if-else, like this:
if (p.GetCommand() == DLMS_COMMAND_AARQ)
frame = 0x10;
else if (p.GetCommand() == DLMS_COMMAND_DATA_NOTIFICATION ||
p.GetCommand() == DLMS_COMMAND_EVENT_NOTIFICATION) {
frame = 0x13;
3)Change "frame = 0x10" into "frame = 0x13",like this:
frame = 0x13;//I change 0x10 into 0x13
frame = 0x13;
4)Done. Anyway, my meter dose not accept the I-frame, so the "frame = 0x10" is useless.
This solution is rough, but it work.
I got AARQ failed.
Can you send a log from the send and received bytes to me by email?
You can get my email address from here:
https://www.gurux.fi/AboutUs
AARQ failed.
I received your email and checked the data. You must increase authentication level. At the moment you are using Authentication level None and meter expect that you are using authentication Low or High.
scron123
I got AARQ failed.
Hi Mikko
I increased the authentication level ,but I got "AARQRequest failed 279."
My command line like this:
pi@raspberrypi:~/Gurux.DLMS.cpp/GuruxDLMSClientExample/bin $ ./gurux.dlms.client.bin -S /dev/ttyS0 -a HighGmac
Here is the content of trace.txt:
<- 03:38:56 7E A0 07 03 21 93 0F 01 7E
-> 03:38:56 7E A0 07 21 03 73 01 40 7E
<- 03:38:56 7E A0 58 03 21 13 E8 E2 E6 E6 00 60 4A A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 67 C6 69 73 51 FF 4A EC 29 CD BA AB F2 FB E3 46 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 1B 26 7E
-> 03:38:57 7E A0 41 21 03 13 2A 7E E6 E7 00 61 33 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D A4 0A 04 08 20 54 30 15 82 40 95 00 89 07 60 85 74 05 08 02 00 BE 05 04 03 0E 01 0A 4A C5 7E
What does "AARQRequest failed 279." mean?
Besides, I got two questions.
1) I changed the AP-title into "VER00001",and here is what I did in GXDLMSSecureClient.cpp:
CGXDLMSSecureClient::CGXDLMSSecureClient(bool UseLogicalNameReferencing,//called in main
int clientAddress,
int serverAddress,
//Authentication type.
DLMS_AUTHENTICATION authentication,
//Password if authentication is used.
const char* password,
DLMS_INTERFACE_TYPE intefaceType) :
CGXDLMSClient(
clientAddress,
serverAddress,
authentication,
password,
intefaceType), m_Cipher("VER00001")//originally it is ABCDEFGH
m_Settings.SetCipher(&m_Cipher);
However, I saw "A6 0A 04 08 41 42 43 44 45 46 47 48" in AARQ.
Why dose it not change ?
2) My meter suggest that the Application-context-name should be Logical_Name_Referencing_With_Ciphered.
But what instruction should I use in command line to do that ?
I got AARQ failed.
You need to change system title, authentication and block cipher keys.
CGXDLMSSecureClient cl;
cl.GetCiphering()->SetSystemTitle(...);
cl.GetCiphering()->SetBlockCipherKey(...);
cl.GetCiphering()->SetAuthenticationKey(...);
lofna
6 years 11 months ago
I am using Sprint 350 established the connection via serial port and got the below
error.
cat trace.txt
TX: 18:06:48 7E A0 07 03 21 93 0F 01 7E
RX: 18:06:48 7E A0 20 21 03 73 73 98 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
TX: 18:06:48 7E A0 44 03 21 10 E6 84 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 30 30 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 1D 76 7E
RX: 18:06:48 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 0F 53 7E
TX: 18:06:48 7E A0 07 03 21 53 03 C7 7E
What is this problem, how can i over come this issue. Here i am using usb to serial cable (FTDI).
Lofna
In reply to Hi, by lofna
Hi lofna,
Hi lofna,
