  3. Read LINYANG Meter's OBIS
read LINYANG meter's OBIS
By samira , 6 March, 2018
I try to read LY-SM100. I used Certification No. 1858 information of dlms site
http://www.dlms.com/conformance/listofcompliantequipment/index.html
and create a new manufacture and then add device like this:
https://www.gurux.fi/sites/default/files/styles/thumbnail/public/forum/…
I can receive this log
2:46:42 PM Initializing serial connection.
2:46:42 PM 02:46:42.736 Info Opening
2:46:42 PM 02:46:42.736 Info Serial Port Settings: Port Name: COM8 Baud Rate: 300 Data Bits: 7 Parity: Even Stop Bits: One Eop: None
2:46:42 PM 02:46:42.846 Info Open
2:46:42 PM HDLC sending:/?!<CR><LF>
2:46:42 PM 02:46:42.846 Sent 2F 3F 21 0D 0A
2:46:43 PM 02:46:43.408 Received 2F
2:46:43 PM 02:46:43.440 Received 2F
2:46:43 PM 02:46:43.486 Received 4C
2:46:43 PM 02:46:43.518 Received 59
2:46:43 PM 02:46:43.549 Received 45
2:46:43 PM 02:46:43.580 Received 33
2:46:43 PM 02:46:43.611 Received 5C
2:46:43 PM 02:46:43.643 Received 32
2:46:43 PM 02:46:43.674 Received 37
2:46:43 PM 02:46:43.705 Received 35
2:46:43 PM 02:46:43.736 Received 33
2:46:43 PM 02:46:43.768 Received 76
2:46:43 PM 02:46:43.815 Received 35
2:46:43 PM 02:46:43.846 Received 73
2:46:43 PM 02:46:43.893 Received 6D
2:46:43 PM 02:46:43.924 Received 74
2:46:43 PM 02:46:43.955 Received 0D
2:46:43 PM HDLC received: /LYE3\2753v5smt<CR><LF>
2:46:43 PM BaudRate is : 2400
2:46:43 PM Moving to mode E.
06 32 33 32 0D 0A
2:46:43 PM 02:46:43.955 Sent 06 32 33 32 0D 0A
2:46:44 PM 02:46:44.565 Received 49
2:46:45 PM 02:46:45.971 Info Closing
2:46:46 PM 02:46:46.111 Info Closed
2:46:46 PM 02:46:46.111 Info Opening
2:46:46 PM 02:46:46.111 Info Serial Port Settings: Port Name: COM8 Baud Rate: 2400 Data Bits: 8 Parity: None Stop Bits: One Eop: None
2:46:46 PM 02:46:46.205 Info Open
2:46:47 PM Send SNRM request.
7E A0 07 03 2D 93 AF A8 7E
2:46:47 PM 02:46:47.221 Sent 7E A0 07 03 2D 93 AF A8 7E
2:46:47 PM 02:46:47.971 Received 49 7E
2:46:47 PM 02:46:47.986 Received A0 20
2:46:48 PM 02:46:48.002 Received 73 D0 3D 81
2:46:48 PM 02:46:48.018 Received 80 14 05 02
2:46:48 PM 02:46:48.033 Received 02 11 06 02
2:46:48 PM 02:46:48.049 Received 02 11 07
2:46:48 PM 02:46:48.065 Received 04 00 00 00
2:46:48 PM 02:46:48.080 Received 01 08 04 00
2:46:48 PM 02:46:48.096 Received 00 00 01 FC
2:46:48 PM 02:46:48.111 Received A8
2:46:48 PM
49 7E A0 20 2D 03 73 D0 3D 81 80 14 05 02 02 11 06 02 02 11 07 04 00 00 00 01 08 04 00 00 00 01 FC A8 7E
2:46:48 PM Parsing UA reply succeeded.
2:46:48 PM Send AARQ request.
7E A0 2B 03 2D 10 5B 06 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
2:46:48 PM 02:46:48.111 Sent 7E A0 2B 03 2D 10 5B 06 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
2:46:49 PM 02:46:49.033 Received 7E A0
2:46:49 PM 02:46:49.049 Received A0 4C 2D
2:46:49 PM 02:46:49.065 Received 30 9F 43
2:46:49 PM 02:46:49.080 Received E6 E7 00 61
2:46:49 PM 02:46:49.096 Received 3E A1 09 06
2:46:49 PM 02:46:49.111 Received 07 60 85 74
2:46:49 PM 02:46:49.127 Received 05 08 01 03
2:46:49 PM 02:46:49.143 Received A2 03 02 01
2:46:49 PM 02:46:49.174 Received 01 A3 05
2:46:49 PM 02:46:49.190 Received A1 03 02 01
2:46:49 PM 02:46:49.205 Received 02 A4 0A 04
2:46:49 PM 02:46:49.221 Received 08 4C 59 45
2:46:49 PM 02:46:49.236 Received 64 72 FB 16
2:46:49 PM 02:46:49.252 Received 5F BE 19 04
2:46:49 PM 02:46:49.268 Received 17 2E 15
2:46:49 PM 02:46:49.283 Received 30 1B 51 89
2:46:49 PM 02:46:49.299 Received E7 06 25 DA
2:46:49 PM 02:46:49.315 Received CF 13 12 45
2:46:49 PM 02:46:49.330 Received B7 5F D7 E5
2:46:49 PM 02:46:49.346 Received 36 A4 2C 2B
2:46:49 PM 02:46:49.361 Received 22 37 CB
2:46:49 PM
7E A0 4C 2D 03 30 9F 43 E6 E7 00 61 3E A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 02 A4 0A 04 08 4C 59 45 64 72 FB 16 5F BE 19 04 17 2E 15 30 1B 51 89 E7 06 25 DA CF 13 12 45 B7 5F D7 E5 36 A4 2C 2B 22 37 CB 7E
2:46:49 PM Disconnect request
2:46:49 PM 02:46:49.361 Sent 01 42 30 03 0D 0A
2:47:09 PM 02:47:09.362 Info Closing
2:47:09 PM 02:47:09.484 Info Closed
Gurux.DLMS.GXDLMSException: Connection is permanently rejected. The application context name is not supported.
and this error
"connection is permanently. the application context name is not supported"
I change logical name reference but again receive that error.
and in dlms site write this device work with long name.
can you help me
best regard
8 years 3 months ago
LINYANG
Can you read the meter with those settings?
samira
In reply to LINYANG by Kurumi
i can connect but not read
i can connect but not read OBIS
LINYANG
After you have made the connection, select "Refresh" from the "File" menu.
It will read all the objects.
samira
The connection is not stable.
The connection is not stable,In fact it cant connect completely. If i have used logical name referencing or short name, receive "Connection is permanently. The application context name is not supported" and immediately is disconnected.there is not "Parsing AARE reply succeeded" .The refresh icon is off. I can read sl7000 with your application correctly, but in this meter i think wrong setting manufacture or device window information.is it correct? How can solve "Connection is permanently. the application context name is not supported" error?
LINYANG
Un-check "Logical Name Referencing".
samira
I do, but i receive again
I do, but i receive again "Connection is permanently. the application context name is not supported" message.
LINYANG
Can you log in with client address 10? Change that and select "Logical Name Referencing" again.
Your meter returns ciphered data now. You need to decrypt it. You need authentication and block cipher keys for that.
samira
Thanks for your attention and help.
I log in with client address 10 and select "Logical Name Referencing", but i receive again "Connection is permanently. the application context name is not supported".
Best regard
Samira
LINYANG
Your meter returns ciphered data now. You need to decrypt it. You need authentication and block cipher keys for that. Ask from the vendor is meter supporting only ciphered connections.
samira
8 years 2 months ago
Thanks for your replay and guide. I do it.
Best regard.
Samira
bisade
7 years 2 months ago
GXDLMSDirector not connecting
Hi There,
I cannot connect to the meter using the GXDLMSDirector. I get "Failed to receive reply from the device in given time" even when the meter sends a response.
Please see below the my log trace
17:18:31 Initializing serial connection.
17:18:31 05:18:31.080 Info Opening
17:18:31 05:18:31.081 Info Serial Port Settings: Port Name: COM12 Baud Rate: 300 Data Bits: 7 Parity: Even Stop Bits: One Eop: None
17:18:31 05:18:31.361 Info Open
17:18:32 HDLC sending:/?!<CR><LF>
17:18:32 05:18:32.361 Sent 2F 3F 21 0D 0A
17:18:32 05:18:32.755 Received 2F
17:18:32 05:18:32.788 Received 2F
17:18:32 05:18:32.821 Received 4C
17:18:32 05:18:32.854 Received 47
17:18:32 05:18:32.888 Received 5A
17:18:32 05:18:32.921 Received 35
17:18:32 05:18:32.954 Received 5C
17:18:32 05:18:32.988 Received 32
17:18:33 05:18:33.021 Received 5A
17:18:33 05:18:33.054 Received 4D
17:18:33 05:18:33.088 Received 44
17:18:33 05:18:33.121 Received 34
17:18:33 05:18:33.154 Received 30
17:18:33 05:18:33.188 Received 35
17:18:33 05:18:33.221 Received 34
17:18:33 05:18:33.255 Received 34
17:18:33 05:18:33.287 Received 30
17:18:33 05:18:33.321 Received 37
17:18:33 05:18:33.354 Received 2E
17:18:33 05:18:33.388 Received 42
17:18:33 05:18:33.421 Received 33
17:18:33 05:18:33.454 Received 32
17:18:33 05:18:33.488 Received 0D
17:18:33 HDLC received: /LGZ5\2ZMD4054407.B32<CR><LF>
17:18:33 BaudRate is : 9600
5:18:33 PM Moving to mode E.
06 32 35 32 0D 0A
17:18:33 05:18:33.496 Sent 06 32 35 32 0D 0A
17:18:33 05:18:33.922 Received 7E 3F
17:18:35 05:18:35.497 Info Closing
17:18:35 05:18:35.864 Info Closed
17:18:35 05:18:35.864 Info Opening
17:18:35 05:18:35.864 Info Serial Port Settings: Port Name: COM12 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Eop: None
17:18:36 05:18:36.006 Info Open
5:18:37 PM Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
17:18:37 05:18:37.007 Sent 7E A0 07 03 21 93 0F 01 7E
17:18:37 05:18:37.021 Received 7E
17:18:37 05:18:37.032 Received 7E A0 1E 21 03 73 C3 7A 81 80 12
17:18:37 05:18:37.039 Received 05 01 80 06 01 3E 07
17:18:37 05:18:37.046 Received 04 00 00 00 01 08 04
17:18:37 05:18:37.054 Received 00 00 00 01 07 22
5:18:37 PM
7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
17:18:37 Parsing UA reply succeeded.
5:18:37 PM Send AARQ request.
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
17:18:37 05:18:37.061 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
17:18:37 05:18:37.112 Received 7E
17:18:37 05:18:37.119 Received 7E A0 36 21 03 30 D7
17:18:37 05:18:37.127 Received 60 E6 E7 00 61 28 A1
17:18:37 05:18:37.134 Received 09 06 07 60 85 74 05 08
17:18:37 05:18:37.142 Received 01 02 A2 03 02 01 01
17:18:37 05:18:37.149 Received A3 05 A1 03 02 01 02
17:18:37 05:18:37.156 Received BE 0F 04 0D 08 00 06
17:18:37 05:18:37.163 Received 5F 04 00 18 02 20 09
17:18:37 05:18:37.171 Received 60 FA 00 C0 3F
5:18:37 PM
7E A0 36 21 03 30 D7 60 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 02 BE 0F 04 0D 08 00 06 5F 04 00 18 02 20 09 60 FA 00 C0 3F 7E
17:18:37 Disconnect request
17:18:37 05:18:37.178 Sent 7E A0 07 03 21 53 03 C7 7E
17:18:37 05:18:37.191 Received 7E
17:18:37 05:18:37.199 Received 7E A0 1E 21 03 73 C3
17:18:37 05:18:37.207 Received 7A
17:18:37 05:18:37.214 Received 01 3E 07 04 00 00 00
17:18:37 05:18:37.222 Received 01 08 04 00 00 00 01
17:18:37 05:18:37.229 Received 07 22
5:18:37 PM
17:18:37 05:18:37.237 Sent 01 42 30 03 0D 0A
17:19:36 05:19:36.237 Info Closing
17:19:36 05:19:36.283 Info Closed
In reply to GXDLMSDirector not connecting by bisade
Hi bisade,
Hi bisade,
You try to connect with Short Name referencing. Check "Use Logical Name referencing" from meter settings and make a new connection.
hajikhan
6 years ago
I am trying to read LINYANG meter but getting below error,
10:12:51 Access Error : Device reports Read-Write denied.
will you please guide for the same.
Best Regards,
Hajikhan
6 years ago
In reply to Hi Mikko, by hajikhan
Hi hajikhan,
Hi hajikhan,
Please, if you have a new question, create a new topic.
I'll answer your question there.
