  3. EMH ITZ and Moxa NPORT 5232
By iamzero5 , 1 March, 2018
I was using EMH ITZ and Moxa NPORT 5232 but it can't connect. Here my device
manufacturer emh
startprotocol: dlms
media :net
auth none
client address 10
adress type serialnumber
serial number i put 8075
logical server 0
host name 192.168.127.254
port 4059
8 years 4 months ago
First check that Moxa and meter serial port settings are same.
Then check that your settings are like described in
EMH metering GmbH settings
iamzero5
In reply to EMH ITZ and Moxa NPORT 5232 by Kurumi
Thank you for the answer and I will look at it.
I guess the problem is with the serial number I can't distinguish where is the serial number is located or should I only input the last 4 digit of the serial number.
Give serial number totally. A serial number is a cover on the meter.
iamzero5
Still not able to connect.
Here is the error from logs:
5:23:57 PM Initializing serial connection.
5:23:57 PM HDLC sending:/?6098075!<CR><LF>
5:24:04 PM Disconnect request
5:24:11 PM Failed to receive reply from the device in given time.
EMH ITZ
EMH ITZ is using IEC 62052-11. You can't use GXDLMSDirector to read your meter because your meter is not DLMS compatible.
iamzero5
In reply to EMH ITZ by Kurumi
Thank you for the response.
Thank you for the response. Is there any way to read this meter?
EMH ITZ
You can make own app. IEC 62052-11 is ASCII based protocol, but there are some variation between meters, so it's not possible to make a generic app that can read all the meter.
  • Rolling-Slots-Bok
  • OskoNadyLoold
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
