  3. Problem Reading a Single Parameter After Successful AARE
Problem Reading a Single parameter after successful AARE
By Shehryar , 17 April, 2017
Hi Team Gurux,
I'm trying to read "Total Active Energy" by using this code:
GXDLMSObject obj = new GXDLMSObject();
obj.LogicalName = "1.0.1.8.0.255";
Object x = Read(obj, 2);
What my code is sending:
00 01 00 11 00 01 00 0D C0 01 C1 00 00 01 00 01 08 00 FF 02 00
What I need to send:
00 01 00 11 00 01 00 0D C0 01 81 00 03 01 00 01 08 00 FF 02 00
How can I set Priority and classID.
Why I'm not able to read "Total Active Energy" ?
Shehryar khan,
keenangeorge
9 years 5 months ago
Hi Shehryan
Hi Shehryan
I am no expert however can you try the below
GXDLMSRegister obj = new GXDLMSRegister("1.0.1.8.0.255");
Read(obj, 2);
Regards
Keenan George
Shehryar
problem solved.
Now I'm getting right response in bytes, how can I convert these bytes data into values ?
keenangeorge
Please send me your output.
BR
Keenan
Shehryar
Value of 1.0.1.8.0.255
00 01 00 01 00 11 00 09 C4 01 81 00 06 00 90 10 4C
keenangeorge
if c# please try this to write to screen.
Object Total_Active_Import = Read(obj, 2);
Console.WriteLine("ImportActiveAggregate: " + Total_Active_Import);
BR
Reading Register
Keenangeorge is right. You are reading register and do like he suggest.
You can also get read value like this:
Read(obj, 2);
Console.WriteLine("ImportActiveAggregate: " + obj.Value);
Value is updated because you are reading attribute 2. That is register value.
If you read attribute 3 (scaler and unit) first value is multiply by scaler.
