I work as tester in IT company, and we're creating electrical things, for example modems. I want to learn a bit about protocols etc. and then I noticed here are python dlms libraries etc. But, for now, I'd want to try DLMSDirector to check some things. But, how can I connect? Our modem is not on Manufacturers list.
All I have are imei, s/n, modem's IP/PIN etc. Modem's type is SIMCOM. Would it be possible to connect to my modem using DLMSDirector any way?
Hi, You can use any modem…
You can use any modem you want to. Modems are usually transparent and only the meter must support DLMS.
