  3. How To Read E450 Prime Meter (L&Gyr)
how to read E450 Prime meter (L&Gyr)
By sunnysouth , 15 January, 2022
i am new to this and my goal is to read the E450 Prime via optical head into a Raspberry pi that i can send over to Home Assistant. (home-assistant.io)
How to read the meter with Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python?
i am able to connect:
gurux_dlms version: 1.0.119
gurux_net version: 1.0.18
gurux_serial version: 1.0.18
ClientAddress: 0x10
Standard: Standard.DLMS
-------- Reading 1 0.0.96.10.7.255 Ch. 0 Status register #7
Index: 2 Value: 0
-------- Reading 17 0.0.41.0.0.255 Ch. 0 SAP Assignment
Index: 2 Value: (1, 'LGZ00000........56')
-------- Reading 64 0.0.43.0.5.255 Ch. 0 Security setup #5
Error! Index: 1 Access Error : Device reports Read-Write denied.
Index: 2 Value: SecurityPolicy0.AUTHENTICATED_ENCRYPTED
Attribute3 is not readable.
Attribute4 is not readable.
Attribute5 is not readable.
-------- Reading 1 0.0.96.10.8.255 Ch. 0 Status register #8
How to see the meter reading from this?
i used this command: python3 main.py -t Verbose -c 16 -s 1 -S /dev/ttyUSB0
the meter is in Spain at Iberdrola distributor
4 years 9 months ago
The client example reads all objects from the meter and shows them on the command prompt. If you want to show current power compsumption find "active power" and current value is there. If you want to read how much electricity you have used in the last hour you need to read "Load profile with recording period 1" object.
sunnysouth
thank you however i could not
thank you however i could not identify these in it, so i decided to use DLMSDirector. Please take a look at the screenshot here
https://www.gurux.fi/node/19588
Where are the power/energy values here? Should i be able to read them without any authentication?
It seems like you can't read them without authentication. If you have the password change the authentication level and the client address and give it a try.
sunnysouth
i do not have a password, can
i do not have a password, can you please help. How is it normally? I thought the meter reading values are open to public as i can see the values with my eye, but i would need in digital format for home automation.
It depends on the meter what you can see or do with the different authentication levels.
You can try with the default L+G low-level password 00000000.
You can also try with 12345678 or ABCDEFGH
If it fails, the meter owner has changed it and it can be anything.
  • yogibear
  • Eric@li
  • BlessyAnn
  • sravya.thota@m…
