  3. Itron SL7000 Connection Problem
By yagizhanyakali , 8 June, 2021
I am trying to connect Itron SL7000 meter via DLMS Director. I am using Utility RS232 port and Moxa UPort 1150 device for this. You can find wiring diagram at attachment.
I tried default parameters (None auth. and Low auth.) but it not worked. I also tried some parameters that I found in forum. You can find my parameters at below.
Manufacturer: Actaris Electricity
Interface: HDLC
Logical Name Referencing: true
Auth: Low
Password: ABCDEFGH
Client Address: 1
Wait Time: 00:00:05
Address Type: Default
Logical Server: 1
Physical Server: 11
Verbose: false
Media: Serial
- Baudrate: 300
- Parity: Even
- Stop Bits: One
- Data bits: 7
Could anyone help me about this issue? I don't know what should I do.
Thanks.
5 years 3 months ago
Change start protocol from HDLCWithModeE to HDLC. You need to try with different baud rates. Start with 9600 and 4800. I believe that the reason why communication fails is the wrong serial port settings.
