  2. Tcp Udp Setup
gxdn
By Administrator , 23 January, 2018
Tcp Udp Setup object is used to define TCP/IP or UDP settings.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. Port
    TCP/IP or UDP port.
  • 3. IP reference
    Logical name of IP4 setup object.
  • 4.MSS
    Maximum Segment Size.
  • 5.Number of simultaneous connections
    How many client can connect to the meter at the same time.
  • 6.Inactivity time out
    If the meter is not receiving requests from the client in the given time, the meter expects that communication is closed. Value is given in seconds.
Actions
There are no actions available for this object type.
Book traversal links for Tcp Udp Setup
  • ‹ Status mapping
  • Up
  • Utility tables ›
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
