  2. Register Monitor
gxdn
By Administrator , 23 January, 2018
Register monitor object can be used to monitor Data, Register, Extended register or Demand register objects.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. Thresholds
    Provides the threshold values to compare.
  • 3. Monitored value
    Defines monitored object and attribute index.
  • 4. Actions
    Collection of scripts to execute if value goes up or down of the threshold.
Actions
There are no actions available for this object type.
Book traversal links for Register Monitor
  • ‹ Register
  • Up
  • Register activation ›
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
