  2. Clock
gxdn
By Administrator , 23 January, 2018
Clock object is used to save current time.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. Time
    Meter’s local date and time.
  • 3. TimeZone
    Used time zone. Time zone information is used in date-time value. See more information from the deviation.
  • 4. Status
    Clock Status.
  • 5. Begin
    When daylight savings begin.
  • 6. End
    When daylight savings end.
  • 7. Deviation
    Deviation in minutes when daylight savings time is used.
  • 8. Enabled
    Is daylight savings time used.
  • 9. ClockBase
    Defines where timing information comes from.
Actions
  • 1. Adjust to quarter
    Sets the meter’s time to the nearest (+/-) quarter of an hour value.
  • 2. Adjust to measuring period
    Sets the meter’s time to the nearest (+/-) starting point of a measuring period.
  • 3. Adjust to minute
    Sets the meter’s time to the nearest minute.
  • 4. Adjust to preset time
  • 5. Preset adjusting time.
  • 6. Shift time
    Shifts the time by given minutes.
Deviation in date time
Deviation is saved to date-time value to tell deviation between the UTC and the meter. Deviation is count from time zone and daylight savings deviation. Daylight savings deviation is added only if daylight savings is enabled.
Deviation is causing problems because DLMS standard says the deviation is from normal time to UTC, not UTC time. Read more from Blue Book 4.1.6.1 Date and time formats.
if your meter is using from UTC to Normal time, set GXDLMSClient.UtcTimeZone to true or define DLMS_USE_UTC_TIME_ZONE in ANSI C. Example IDIS is using DLMS way and India, Saudi Arabia and Italy DLMS sub standards are using UTC to Normal time.
Below is example what this means using Paris Time zone (UTC+60).
  • DLMS and IDIS: -60 minutes.
  • India, Saudi Arabia and Italy: 60 minutes.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
