  2. GXDLMSDirector Menu Structure
By Administrator , 23 January, 2018
Gurux DLMSDirector is an easy-to-use application to communicate with DLMS/COSEM smart meters.
File menu
  • To create a new collection of Devices, select New.
  • To add a Device in collection of Devices, select AddDevice.
  • To open an existing collection of Devices, select Open.
  • To save the current collection of Devices, select Save.
  • To save the current collection of Devices on a different name or to a different location, select Save As...
  • To retrieve the register objects of selected Collection or Device, select Refresh.
  • To exit the application, select Exit.
View menu
  • To view / hide the toolbar, select / unselect ToolBar.
  • To view / hide the statusbar, select / unselect StatusBar.
  • To view / edit the properties of selected Collection or Device, select Properties...
Tools menu
  • To connect to selected Collection or Device, select Connect.
  • To disconnect from selected Collection or Device, select Disconnect.
  • To get the values of selected Collection or Device, select Read.
  • To write value(s) of selected Data Object, select Write.
  • To remove selected Device or Register from the list, select Delete.
  • To view the Log as a text file, select View Log.
    Note: The text file does not update, it only shows the current rows of the Log.
  • To erase the rows of the Log, select Clear Log.
  • To view / edit / add device manufacturers, select Manufacturers...
  • To view / edit OBIS codes, select OBIS codes...
Graph menu holds the command for displaying the Graph Items of the selected Object.
Help menu holds commands for opening
  • this manual (Contents...), and
  • the application information box (About...).
Shortcut Icons on GXDLMSDirector ToolBar
New Create a new collection of Devices.
Open Open an existing collection of Devices
Save Save the current collection of Devices to the file.
Connect/Disconnect Connect to / disconnect from selected Collection or Device
Read Read the values of selected Collection or Device
Write Write the value(s) of selected Data Object
Properties View / edit the properties of selected Collection or Device
Delete Remove selected Device or data object from the list
