  3. COMPTEUR INFORMATIONS
By mehdi , 22 September, 2016
I thank you from my heart for your reply
I encountered problems during the ACE configuration SL7000
I need the following information
                 - HDLC Addressing Scheme _____________
                 - Physical Device ID ___________________
                 - Client ID __________________________
                 - Logical Device ID ____________________
                 - Application Context__________________
                 - Level Authentication (Password) ________
10 years 1 month ago
You can read your SL7000 with GXDLMSDirector. You can get correct parameters from or here
mehdi
urgent !!!
Good evening sir
Thank you for your assistance, the application works well I use it , but i need to knowl, but i need to know
Please can I ask you another question
it is possible to configure the sync 2000 for Ethernet TCP protocol ? if yes how ??
and another question please ??
is it possible to configure a sync gatway 2000 for Modbus RTU slave / mastre ??
Yes it is. Just change interface type from HDLC to WRAPPER. I can't remember client and server address now, but try to set 1 and 1. Let me know if that is not working.
mehdi
hi,
I explain my problem, I am a student and I have a project to realize
I have 10 counters ACE SL7000 operation that the protocol DLMS / COSEM and I have a MicroLogix 1100 controllers supporting The Following communication protocols ethernet controller so I used a passrelle to change the protocol "SYNC 2000 '' that needs the EasyConnect Application
please, if you have informaion or a help from you
GXDLMSDirector it is also for configuring sync 2000?
how I can change in HDLC to WRAPPER
