  3. Starting With DLMS and a ZIV Meter
Starting with DLMS and a ZIV meter
By Pelmar , 15 December, 2015
Good day,
I´m starting with DLMSDirector and the smart meter ZIV 5CTM. I have been changing the configuration serveral times, but i could´t stablish connection with the meter. Reading other topics I realice that the smart meter doesn´t have the dlms identification in the meter. ¿Does this mean that is not compilant with dlms standart? I ask the manufacturer, and they said that it should work.
¿Any ideas?
Log created 17:44:06
17:44:09 Initializing serial connection.
17:44:10 Send SNRM request.
7E A0 07 03 03 93 8C 11 7E
17:44:15 Failed to receive reply from the device in given time.
en GXDLMSDirector.GXDLMSDevice.InitializeConnection() en C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:línea 345
en GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) en C:\Projects\GXDLMSDirector\Development\MainForm.cs:línea 939
Thanks for your time
Administrator
10 years 11 months ago
ZIV meters
We are Readingin some ZIV meters, but we are using TCP/IP connection and are are using serial port. Am I right? Your settings are wrong. Try to change client id to 10.
Pelmar
10 years 10 months ago
Ziv
Hi ,
We are trying to read the meter trought a IEC 62056-21 optical probe. We change the configuration as suggested but we still receive the same answer....
ZIV meters
As I told we are reading Ziv meters throught TCP/IP, but try to
change starting protocol to IEC from DLMS.
Serial port settings are always little problematic,
but after they are correct you should be able to read your meter.
Pelmar
Ziv meters
Hello Mikko,
Thanks for your quick answer.
I contacted with the manufacturer and in theory, the meter uses DLMS over HDLC and the port configuration is 9600-8-N-1. Gurux supports this specification ,right?. When you say that you are connecting througt TCP/IP you mean that you are using a RS232/Ethernet gatway? I will test it using one i have at home.
I have been playing changing the parameters as you recomenden but nothing, and I still don´t receive the firt sign of life.
This device as I said previosly don´t have the DLMS label instead has the PRIME (DLMS over PLC).
May be this unit have a different configuration?
Thanks a lot
Ziv meters
Yes, we are supporting that. We are reading other meter from ZIV where is TCP/IP interface.
Try first with these settings:
Client address: 1
Server address: 1
If that fails, can you ask what client and server address manufacturer is using for that meter.
We can solve them, but it's faster to ask from the manufacturer.
marcogohi
8 years 9 months ago
We have the same problem as
We have the same problem as Pelmar with ZIV meters through serial coms.
Any update?
Ziv meters
What serial port settings you are using? Are you using optical head or serial port connection?
