By sid033, 21 August, 2012
I get an error message "Value is not expected" when I try to connect device .
What's the problem?
--comments: When I use version 7.0.0.2 the error message is "invalid tag"
This meter is a new product of our company. I was expected to pass the DLMS Conformace testing. So,I want to use DLMSDirector to test my protocol program. That's all .
The manufacturer setting are:
use LN ref:false
use iec62056-47:false
inactivity mode:keep alive
inactivity interval:40
startprotocol :DLMS
Authentication:none
client address:0x01,one byte
server address:
addresstype:default;
type: uint32
phy:0x0101 log 0x0001
The device settings are
manufacturer: chint meter
startprotocol:DLMS
media:serial
authentication:none
wait time: 5
client address:0x01
address type:default
phy:101 log:1
serial port:com1,9600,8,"N",1
It seems that your data is correct.
We are releasing new version from GXDLMSDirector in this week.
Hopefully it will fix your problem.
Can we read your meter using internet?
If we can send ip address to me and I can try to read your meter if you want to.
Hi Mikko:
I write a program transfer data between RS485 and Ethernet. IP/Port:122.224.171.186/2108. you can create a socket on this ip and port,and send HDLCFrame directly to the socket .
Thank you very much!
Yun Ling @chint China
settings
client mac:0x01
server mac:0x0101
server log:0x0001
lowest security level
app ctx:short name with no cipher
conformance 1c 1a 20
connecting problem
What meter you are using?
I developed a new product
use LN ref:false
startprotocol :DLMS
Authentication:none
server address:
type: uint32
startprotocol:DLMS
media:serial
authentication:none
wait time: 5
client address:0x01
phy:101 log:1
om,let me try to do it
Hi.
The meter doesnot support IEC62056-47.But I can write a program to transfer data between RS485 and Ethernet. Is it OK?
I have setup a socket server
Hi Mikko:
Is anybody here?
I'm still online~ Is anybody here,who can give me some advise.
Connecting problem
You can download new version from GXDLMSDirector.
We have improved error descriptions.
