  3. Connecting To Iskrameco ME382- Single Phase Meter With Optical Probe
Connecting To iskrameco ME382- Single Phase Meter with Optical Probe
By Mesotox , 14 April, 2026
Hey, I bought an ME382 and wanted to connect to it with DLMSDirector But somehow it dosnt work. No matter what settings I Use.
I tried to read Things with WindowsPowerShell wich workt partially But not with DLMSDirector
7 months ago
Hi, Select Iskraemeco as a…
Select Iskraemeco as a manufacturer. If you are using optical probe select HdlcWithModeE. If you are using direct serial port connection select HDLC as the interface type.
Some meters are configured to support only Low authentication and you get an eror if you connect without authentication (None). Try to change the authentication level to Low.
Those settings work in Iskra ME382 meters in Finland.
